4.10s too much after trans swap!
Old September 17th, 2008, 02:19 PM   #1
2001 Mustang GT
smccoy916 is on a distinguished road
So I recently swapped my car to a 5 speed and now my gears are too much for my setup. I have to shift twice before I get through an intersection. I cant get traction in first at all and second is almost as bad and Im running a 10.5" wheel out back with DR's. I was going to put my 3.73s back but now I'm thinking about 3.55s. What do you guys think?
Old September 17th, 2008, 02:56 PM   #2
sjr56's Avatar
2001 MUSTANG GT VERT
sjr56 is on a distinguished road
With a stick and a SC I would probably run 3.73s. With Forced Induction usually you don't need as much gear as N/A. It depends what you want out of your ride, 3.55s might be fine for you if you street cruise alot.
____________________________________
BBK O/R X, Flowmasters, MGW, Spec stage II, MM CC plates, MM Panhard bar, Eibach Pro kit, Bilsteins, Accufab plenum, Mac TB, K&N RAI, 4.10's, FR500's, Nittos.
Old September 17th, 2008, 03:00 PM   #3
02S281's Avatar
02 Saleen Speedster #681
02S281 is on a distinguished road
im throwing 3.73's in mine. I have the stock 3.27's now and have driven a car with 3.73's and i feel those are the best choice of gears for a cars thats FI or just making alota power
2002 Saleen #681
-Kenne Bell 2.1 intercooled 10psi w/BAP
-Kenne bell inlet components
-Kenne bell switch chip
-75mm throttle body
-90mm mass air meter
-Nitto 555R's 285/45/18
Old September 17th, 2008, 03:57 PM   #4
2001 Mustang GT
I thought everyone would say 373s. I went from 373s to 4.10s while it was an Auto and didn't notice a big difference between them so I was a little worried that the 3.73 would feel the same as it does now. I guess I can always switch to the 3.55s if I don't like the 3.73s and it would only be a few hours and a new crush washer.
Old September 17th, 2008, 05:21 PM   #5
2kGT's Avatar
2kGT has a little shameless behaviour in the past
What is your setup? Unless you got a roots blower your driving skills are the lostered. Here is an idea - dont hammer it to the floor everytime you press the gas.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old September 17th, 2008, 05:47 PM   #6
2001 Mustang GT
My Mods are listed in my garage with the exception of the 5speed and spec stage 2+ clutch that I just installed. You dont have to hammer the throttle in my car to get loose in first or second. I'm no pro but like everyone else I think I'm a decent driver.
Old September 17th, 2008, 06:00 PM   #7
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
Nea, 410s all the way, I have a centri blower and 373s, I wish I went with 410s instead.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old September 17th, 2008, 08:38 PM   #8
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
What transmission are you using? And what is your engine setup?
Old September 17th, 2008, 08:56 PM   #9
2001 Mustang GT
Its a 3650 out of an 04 GT. My motor setup is listed in my garage.
Old September 17th, 2008, 08:58 PM   #10
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
i looked at your garage.. I don't see why you don't love 4:10's.
only 2 reasons I can think of is that you do a lot of highway driving/roll racing or your tires are shit.
Old September 17th, 2008, 09:20 PM   #11
2001 Mustang GT
My BFG DR's have seen better days so I will replace the tires before I decide to change gearing again. Maybe I'm just not used to it yet. Its only been a 5 speed for a week.
Old September 17th, 2008, 09:21 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
that's probably it honestly. I have had 3:73's and 4:10's in my old 01 GT and the 4:10's hands down were better.
Old September 17th, 2008, 09:25 PM   #13
2001 Mustang GT
So what did you run for a clutch? My spec clutch is giving my leg a workout.
Old September 17th, 2008, 09:26 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I ran a king cobra.
Old September 17th, 2008, 09:30 PM   #15
Im making 300+ rwhp with a spec stage 3 clutch and im coming across the quarter fairly close to the redline in 4th gear with 4.10s. I cant understand why you're not liking them. I dont have any issues with wheelspin unless i hit it too hard in first or second. Otherwise they pull pretty strong compared to the stock gearing.
Old September 17th, 2008, 09:34 PM   #16
2001 Mustang GT
How much power did you put down with that car? NOS or FI?
Old September 17th, 2008, 09:36 PM   #17
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I had a 120 shot on her and full bolt on's and a cam.
I really have no idea what I was making honestly.
the car dynoed 238/271 with just a jlt and a cat back.
Old September 17th, 2008, 09:36 PM   #18
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
dont use first. when you stop, just put it in 2nd
MAD Stangs #8
Old September 17th, 2008, 09:37 PM   #19
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ that's a good way to decrease mpg.
Old September 17th, 2008, 09:40 PM   #20
+1
and a nice way to kill your 60ft in the quarter
Threads Similar to: 4.10s too much after trans swap!
auto to manual trans swap Nikonluvr 2005 - 2010 1 February 25th, 2008 10:35 PM
Reverse Lights?? (Trans Swap) the real shocker 99-04 2 December 27th, 2007 10:45 PM
Trans swap? gregkelley 5.0 Mustangs 5 March 16th, 2007 10:00 PM
C4 Trans Swap. CantDrv55 99-04 1 February 28th, 2007 02:54 PM
m5r2 trans swap sylchoneycutt 5.0 Mustangs 0 January 22nd, 2007 10:55 AM
