Discussing p1000 touble code and motor won't start in the 99-04 Forum. Did you disconnect any of the steering column wiring or mess with anything under the ...
Old September 17th, 2008, 10:34 PM   #21
Did you disconnect any of the steering column wiring or mess with anything under the dash during the swap? If not is it possible you're battery was weak during re-programming?
Certified Master Technician
Also FORD certified
-Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist.
Old September 17th, 2008, 10:34 PM   #22
texasd18e's Avatar
2001 Mustang
13.2
one more important note. my original battery was dead after the swap so i had to install a new battery. i had the pats problem before and i know that the battery can trigger it so i disconnected the new battery for 20 seconds, reconnected it and still had the same problem.
Diablo Tuner
4.10s
flowmaster 40s
port polished PI heads
mac cai
steeda tri ax
bbk long tube ceramic headers
bbk x pipe
PP Typhoon Intake
Old September 17th, 2008, 10:36 PM   #23
texasd18e's Avatar
2001 Mustang
13.2
i didnt touch anything under the dash. yeah i think it was a weak battery that triggered it but how do i fix that problem?
Diablo Tuner
4.10s
flowmaster 40s
mac cai
steeda tri ax
bbk x pipe
PP Typhoon Intake
Old September 17th, 2008, 10:47 PM   #24
I believe u said you re-programmed the pcm. What flash tool or chip did you use. If the battery was weak during reprogramming it is possible you lost communication and only have a partial file installed. You could also have a blank PCM. A weak battery can cause the PATS module to turn on but the PCM which takes alot more power to run will not which results in the flashing theft light due to lack of communication. Once the voltage level is restored or returned to normal everything should operate normally. Is you're theft light still flashing now/ do you have command start. Also make sure you have a chipped key in the ignition, I have seen it a few times and done it myself where I had the wrong key/door key in the ignition or another pats key on my chain causing interference.
Also FORD certified
Old September 17th, 2008, 10:55 PM   #25
texasd18e's Avatar
2001 Mustang
13.2
yeah i've done the key thing too. No command start and i have a diablo tuner. the theft light still flashes. i'm thinking tune the pcm again?
Diablo Tuner
4.10s
flowmaster 40s
mac cai
steeda tri ax
bbk x pipe
PP Typhoon Intake
Old September 17th, 2008, 11:03 PM   #26
Try putting it back to stock. Then see if it starts.
Also FORD certified
Old September 17th, 2008, 11:04 PM   #27
If it does try tuning it again.
Also FORD certified
Old September 17th, 2008, 11:05 PM   #28
texasd18e's Avatar
2001 Mustang
13.2
i like where your head is at. youre doin good things.
Diablo Tuner
4.10s
flowmaster 40s
mac cai
steeda tri ax
bbk x pipe
PP Typhoon Intake
Old September 17th, 2008, 11:15 PM   #29
Thanks, If that doesn't work or you have problems programming just reply back and we will get it running one way or another.
Also FORD certified
Old September 18th, 2008, 01:07 PM   #30
Authorized Vendor
Trick Tuners's Avatar
KB'd GT
contact your diablo dealer and have him send you a tune with pats off.
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX wideband products @ Trick Tuners
email joe@tricktuners.com
PM for super MM member deals!
Super Cheap Motorsports Camera to record the Action!
Threads Similar to: p1000 touble code and motor won't start
codes p1000 and p1605 gtdan 96-98 8 August 19th, 2008 05:49 PM
touble with engine. suds488 96-98 9 April 16th, 2008 08:57 PM
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan Poweradders 3 January 2nd, 2008 10:34 PM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 05:56 PM
motor wont start HELP!!! P.O.S-GT 5.0 Mustangs 7 February 10th, 2007 01:24 PM
