Discussing Engine in the 99-04 Forum. The original used engine we had did not run. So now we have a set ...
Old September 19th, 2008, 06:51 PM   #1
dmachine22's Avatar
1999 Mustang GT
Engine
The original used engine we had did not run. So now we have a set of heads off a 2001GT going on a 2000GT with the T-45 will any of these fit with the heads and transmission?
COUGAR 97 8-280 (4.6L, VIN W)
CROWN VICTORIA 96 (8-280, 4.6L), gasoline, VIN W (Romeo), exc. Police pkg
CROWN VICTORIA 97-99 (8-280, 4.6L), gasoline (VIN W, Romeo), exc. Police pkg
GRAND MARQUIS 96 (8-280, 4.6L), VIN W (Romeo)
GRAND MARQUIS 97-99 (8-280, 4.6L, VIN W)
LINCOLN & TOWN CAR 96-99 (8-280, 4.6L, VIN W)
MUSTANG 96-97 8-280 (4.6L), SOHC (VIN X)
THUNDERBIRD 97 8-280 (4.6L, VIN W)
"Sold"
Old September 19th, 2008, 07:11 PM   #2
97S281's Avatar
1997 Saleen S281
yes, 2001 and 2000 heads are perfectly interchangable. if you look they have the same casting numbers.
Old September 19th, 2008, 07:12 PM   #3
dmachine22's Avatar
1999 Mustang GT
Okay so will these motors bolt up to a t-45
"Sold"
Old September 19th, 2008, 07:15 PM   #4
97S281's Avatar
1997 Saleen S281
I'm not sure about all the other models you have listed, but you should check with the dealer for sure as all 96-98 mustang 4.6 motors were non p. i. and you would lose significant hp if you bolted npi heads and intake to a p.i.motor. also, npi heads are not ment to be used with a p.i.intake without an installation kit or alot of gasket maker.
Old September 19th, 2008, 07:19 PM   #5
97S281's Avatar
1997 Saleen S281
the t-45 was the stock mustang 5 speed from 96+. They changed somewhere along the way to 2004 but i'm not sure of the year they made the switch. It should bolt up to any mustang 4.6. though. the only thing you need to make sure of is the correct flywheel and bellhousing.
Old September 19th, 2008, 07:21 PM   #6
dmachine22's Avatar
1999 Mustang GT
well I have the PI's off a 01GT all I need is a motor for a friend and the only ones I found in a reasonable $ range is the above listed. So if the 96-98 motors bolt up to a 00GT T-45 then ill do the swap and change the npi to the pi.
"Sold"
Old September 19th, 2008, 07:29 PM   #7
97S281's Avatar
1997 Saleen S281
sounds like your best plan. you can definately put the 01 p.i.'s onto the 96-98 gt motor. you will get a bump up in compression too. the npi motor with the pi set up produces 10:1 compression. i believe your stock p.i. motor only produces 9:1 or 9.5:1.
Old September 19th, 2008, 07:37 PM   #8
dmachine22's Avatar
1999 Mustang GT
I did not know that. Thanks.
"Sold"
Old September 19th, 2008, 07:43 PM   #9
97S281's Avatar
1997 Saleen S281
don't thank me, REP me!!!!!!!!!!!!!
Old September 19th, 2008, 08:17 PM   #10
dmachine22's Avatar
1999 Mustang GT
rep
"Sold"
Old September 20th, 2008, 12:53 AM   #11
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
the t45 will bolt up to any of the mod 4.6 and 5.4. all the x vin motors are windsors, and w vin are romeo's. the heads will bolt to any block, just have to make sure you run the correct valve cover with the head. the romeo motors have 6 bolt f/w and windsors generally have the 8 bolt. the bellhousing on the t45 will only go to the mod motor, i believe the 3650 is the same. the mustangs went to the 3650 mid 01, and all mustangs went to electronic speedo in 99+.
stock long block, bolt ons, slicks, and a little squeeze
N/A-12.81@103.7
N2O-11.79@115.8
parting out 04 cobra, pm me for details
Threads Similar to: Engine
Engine mount to Engine bolts FoxHoss 5.0 Mustangs 3 April 17th, 2008 11:59 PM
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 11:14 PM
Will My LT Headers From My Stock Engine Fit On The Mach 1 Engine? tcasoccer13 96-98 12 December 3rd, 2007 10:13 AM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 06:53 AM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 06:09 PM
