problem, sputtering, starving. need help!!
Old September 20th, 2008, 12:24 AM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
i have been working on my friends 2001 V-6 auto for a couple days now and it wasn't running as of last night until i replaced the alternator, battery and camshaft position sensor. the car runs and drives now but not well. the problem is that when normally accelerating it sputters and has absolutely no power. the car is not showing a check engine light at all but when you hammer on it, it sputters and chokes and then the check engine light starts to flash for a short time then the light turns off when you drive it easy again. just wanted to kno if anyone had any ideas or could possibly tell me whats wrong with this poor thing.
Thanks.
Old September 20th, 2008, 12:27 AM   #2
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
I doubt it's the alternator or battery unless the volt meter is reading low. Im guessing it's something with the CPS or CPS circuit. That would definitely do it, but at the same time, you should always troubleshoot everything
"peak hp doesn't mean ish... Its about the area under the curve mannn..."
Old September 20th, 2008, 01:00 AM   #3
Still too slow
bwoody1713 is on a distinguished road
Send a message via AIM to bwoody1713
Last I checked when the CEL starts flashing that means the motor is misfiring. Check your plugs and COPs. One of them may have gone bad. Probably a COP, that's what mine turned out to be.
Old September 20th, 2008, 01:40 AM   #4
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
even though the CEL may not be constantly on, the PCM might still be saving a code. Try and pull the code, and see if anything shows up.
Old September 20th, 2008, 01:43 AM   #5
dude496's Avatar
04 Mustang GT
One other thing...the crank position sensor is in circuit with the cam position sensor (they work hand in hand).
Personally i'd lean more towards the sensor vs. the COP since the car is stalling out...the car will run on 5 out of 6 cylinders, it'll run rough, but it will still run. Now if you have multiple COP's bad, then yeah it will cause that problem. If the crank position sensor is bad, it will definatly cause your problems. Then again, i'm not sure if the v-6 uses a crank position sensor.
Old September 20th, 2008, 10:31 AM   #6
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
KevinJ99GT will become famous soon enough
I think its bad COP to i had to replace mine about 2 weeks ago because it did that, but never got a check engine light.
- full bolt on's, hitech stage 2's, zex 100 shot
Old September 20th, 2008, 10:53 AM   #7
burnout5.0's Avatar
448whp/475wtq
Thanks guys for all the input but whats a COP?
Old September 20th, 2008, 11:13 AM   #8
dude496's Avatar
04 Mustang GT
Coil over plug.
You probably should be asking in the v-6 section...not sure if the 01 v-6 used COPs or still used a distributor pack.
Old September 20th, 2008, 11:43 AM   #9
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
sixxers don't have COPs.
check plugs, wires, and coil packs. If that isn't it go to another section of the motor. The fact it isn't throwing a code is weird. So I would just start with those.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old September 20th, 2008, 12:48 PM   #10
burnout5.0's Avatar
448whp/475wtq
i just drove it today its now throwing a CEL too
Old September 20th, 2008, 12:51 PM   #11
Shibby50's Avatar
Shibby50 is on a distinguished road
Send a message via AIM to Shibby50
a bad catalytic converter can cause the sputtering and such at high rpm's
2000 GT Convertible
Wrecked
2001 Trans Am
Old February 26th, 2009, 01:32 PM   #12
JBird is on a distinguished road
whose car is this chris's?
Threads Similar to: problem, sputtering, starving. need help!!
Missing sputtering noise KevinJ99GT 99-04 20 September 6th, 2008 04:00 PM
sputtering, popping, surging mxnate116 5.0 Mustangs 18 August 20th, 2008 02:57 AM
Friends Mustang Sputtering 935.0 V6 Mustangs 12 May 6th, 2008 01:00 AM
starving for gas Crob09 2.3 Mustangs 1 April 7th, 2008 10:58 PM
GT Sputtering? outlawedstang 99-04 12 December 13th, 2007 10:44 PM
