smoke
Old December 21st, 2005, 02:07 PM   #1
2001 Mustang Cobra
WVSNS& is on a distinguished road
Send a message via AIM to WVSNS& Send a message via Yahoo to WVSNS&
smoke
Has any w/a 4.6 dohc experienced smoke at startup as a regular thing?
Old December 21st, 2005, 04:15 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
blue smoke- ike burning oil or what color smoke coming from where?
ModdedAutos
1999 Mustang V6
Old December 21st, 2005, 04:32 PM   #3
99mustang232's Avatar
99mustang232 is on a distinguished road
probably a sign of warn valve seals, does it smoke on startup then go away... and smoke more the longer it has sat?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old December 21st, 2005, 04:45 PM   #4
Oil smoke after startup from an engine that has been shut off for a while is usually the result of worn valve guides or valve stem seals. When the engine is shut off, the hot oil leaks past the seal or guide and drips down on the piston top. When the engine is started, the oil burns off and creates the smoke for the few seconds of operation
Old December 21st, 2005, 05:26 PM   #5
2001 Mustang Cobra
smoke
Smokes at start up and quits after about ten seconds from the tailpipes. Smoke is mostly a grey w/a hint of blue but real suttle.
john
Old December 21st, 2005, 05:43 PM   #6
14.79 @ 92.15
could be just a little bit of minor oil burn off like posted up there^^
ModdedAutos
1999 Mustang V6
Old December 21st, 2005, 06:05 PM   #7
Bill is on a distinguished road
maybe its just steam from the condensation in the exhaust system
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old December 21st, 2005, 06:25 PM   #8
blue smoke = burning oil
Old December 21st, 2005, 06:30 PM   #9
14.79 @ 92.15
yea blue smoke= burning oil, a clear haze is just normal for winter time lol. hopefully it isnt anything too serious, your CEL isnt on is it?
ModdedAutos
1999 Mustang V6
Old December 21st, 2005, 07:25 PM   #10
2001 Mustang Cobra
No codes yet.Got a steeda oil seperator too.
Old December 21st, 2005, 07:32 PM   #11
mine does this too w/80k on the ticker... not much you can do unless you wanna pay for a valve job? im sure you could also do a leakdown test... but this is a common problem not just for mustangs.
Old December 21st, 2005, 09:41 PM   #12
Roadhawg is on a distinguished road
Is your Cobra supercharged?
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old December 30th, 2005, 07:14 PM   #13
2001 Mustang Cobra
No supercharger. Last year of the na. The valves and heads were done 10k ago and the steeda seperator seems to work well. Still get a bit at start up but not anywhere close to what it was.
john
Old December 30th, 2005, 09:18 PM   #14
it's leaking past the valve guides and seals.
88 Mustang Coupe
www.rickscarcare.net
Old December 31st, 2005, 04:57 AM   #15
john sounds to me like you need a sweet cam and some reworked heads
Old January 2nd, 2006, 04:13 PM   #16
Casper98GT's Avatar
Have a 97 Cobra that did the same thing. Shut it off, and some white smoke would breeze out of the tailpipes. I had a problem with the IMRC's the controler decided it didnt want to work anymore. So i also removed IMRC runners and cleaned them up and worked them back and fourth. Havent seen much smoke anymore. My 98 Gt lets out a small amount nothign like the cobra did though. Also have seen Worn valve guides like others have suggested. And the 32v's do have problems with valve's leaking by. had a 91 Gt that did it for a good minute or so, valve seals were pretty bad in it. lol.
91 LX, 5spd.
Ex:Toyota/Ford tech
Threads Similar to: smoke
Smoke-em HMUSN The Clubhouse 0 November 9th, 2007 08:54 PM
To much smoke Scrapdaddy SR. V6 Mustangs 17 June 8th, 2007 01:56 AM
smoke coreyfitz 5.0 Mustangs 3 April 14th, 2007 01:26 AM
smoke? therapist 99-04 2 January 29th, 2007 04:32 PM
Smoke nHuman 96-98 7 December 29th, 2006 01:10 PM
