2003 Mustang GT
longtube header install question
I'm thinking of getting MAC longtubes, MAC shortty o/r prochamber, and borla stingers. Do i need to purchase any extra hardware for a shop to do the install? My mustang is a 2003 gt with about 73000 miles on it. I dont care about the MILs or O2 extensions because i will soon also get a SCT tuner and i should be able to turn that stuff off correct? I'm more worried about gaskets and things like that. I just want everything in the install to be smooth and how much do you think labor will be? yes i know that it might be expensive because of the longtubes.
![]() iTrader: 1 reviews
well you need the o2 extentions because your stock o2 sensors wont fit in with lt's
mils youre fine though im pretty sure if its an exhaust shop theyll have all the parts needed to do the header install.
I'd recommend new gaskets, locking header bolts and o2 extensions. Bassani makes a great set of gaskets. The locking header bolts will help cut down on exhaust leaks and you won't be out there every other week tightening them down. And the o2 extensions aren't exactly necessary, but it beats having to cut up your o2 sensors to extend the wires yourself. At 73k miles, you might want to consider getting new o2 sensors anyways.
Percys seal4good aluminum gaskets and stage 8 locking bolts, do it right the first time.
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
Percey or ford racing gaskets and some extensions. And some flex head ratcheting wreches and alot of patience
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
You will still need o2 extensions. The SCT (or any tuner) will only turn off the rear o2s. The extensions allow you to attach the front o2s in the long tube header.
Threads Similar to: longtube header install question
| Header install question for OBX | black05stxjt | 2005 - 2010 | 31 | July 25th, 2008 01:42 AM |
| Longtube install help | 90Stang | 2005 - 2010 | 23 | June 2nd, 2008 10:19 PM |
| JBA Longtube Header Package!! | Derek@DRI | 2005 - 2010 | 1 | May 12th, 2008 01:03 PM |
| longtube header install time | thecloneranger | 2005 - 2010 | 3 | February 19th, 2008 12:37 PM |
