Typhoon problems...Why Me?
Old December 5th, 2006, 06:55 PM   #1
Max02420 is on a distinguished road
I bought the typhoon intake manifold when I blew the stock one. The job was easy but the only thing I noticed is that the gaskets looked cheap. I put them on anyways and they were fine for a while but recently started leaking. I origonally tightened the bolts to 18lbs as recommended during install, and tightened them once later that week to ensure they were still tight. I had the torque on 10lbs and they recommended 18 so I thought it would be OK. The bolt turned once and sheared off the head of the bolt. I was so damn pissed I could have kicked the car.
The questions that I have are...
1) Should I have it drilled and tapped? The only thing I worry about is that I might still have the problem later.
2) Take the manifold off AGAIN. Back the screw out myself with a pair of plyers and change the gaskets?
3)If im going to go as far as #2 states, I always told myself I would never do that job again without changing out the heads/cams. Should I just do this and suck it up, maybe have head work done?
Old December 5th, 2006, 08:05 PM   #2
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
#3 for the win
Old December 5th, 2006, 08:17 PM   #3
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
#4--Stayed away from the typhoon intake
Old December 6th, 2006, 06:01 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
#3 since head work was already in the plans to do if it went that far. you gotta keep your word to yourself
Old December 6th, 2006, 08:03 AM   #5
sweet99 is on a distinguished road
I agree with #4 but since that is not an option if you can truly afford the work you had planned get it done and be happy. Of course get new gaskets and replace the bolts. The bolts were not from Typhoon folks were they? Mark
'99 Convertible. 4.10's, PYPES catted X-pipe and catback.
UDP's. 75mmBBK TB/plenum. JLT CAI. UDP's, Brenspeed custom tuned SCT. SVO intake & SHM cams this winter! Lord willing.
Old December 6th, 2006, 10:07 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Isn't that Typhoon piece of shit made by that over seas company that has been ripping off Edelbrock? I would stay far away from that junk.
Its amazing what people will do to save a buck these days. In the long run it never works out. Keep supporting those over seas rip offs and wonder why people go jobless in this country.
Threads Similar to: Typhoon problems...Why Me?
Typhoon Intakes kolby1976 99-04 17 June 13th, 2007 08:32 PM
typhoon intake? 4.6gtmarine 99-04 5 February 20th, 2007 10:56 PM
Typhoon Intake DragonFreak 99-04 72 November 29th, 2006 08:07 AM
Typhoon Intake ayyubam2002 General Tech 1 August 6th, 2006 04:21 PM
