HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability?
Old September 29th, 2008, 04:18 PM   #1
the1968jeepthing is on a distinguished road
Send a message via AIM to the1968jeepthing
I have aquired a project '02 4.6 SOHC mustang that has the engine completely apart in various boxes and such. After getting the block and everything mostly together i went to mount the flywheel and suprise suprise the flywheel is 6 bolt and the crank is 8 bolt. After some research i found out that whoever had this vehicle before was planning on putting in a cobra crank. Everything else on this engine is bone stock.
My question(s): can i get away with just buying a new cobra flywheel? will the balence be all messed up? will i have to get a new clutch assembly as well? Or do i have to go buy a new origional 6 bolt crank?
Thanks,
-Brian
Old September 29th, 2008, 07:11 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the cobra flywheel is an 11in set up. you can get an 8 bolt gt flywheel that is set up for a 10.5. just look up for a 99-00 gt, widnsor motor (vin x), and there ya go. these motors are supposed to be internally balanced, so the flywheels shoulnt effect anything. measure the clutch kit you have and purchase for it. or buy a flywheel/clutch kit together for the same vehicle.
Old September 30th, 2008, 12:39 AM   #3
perfect! thanks for the info
Threads Similar to: HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability?
cobra/gt crank the same? 97S281 4V / SVT 15 August 25th, 2008 10:07 PM
I need a crank pulley bolt ASAP! 03_StangGuy 99-04 1 August 10th, 2008 12:59 AM
crank bolt and udp's bren-stang 2005 - 2010 10 March 12th, 2008 10:25 AM
New Crank Bolt for UDP's - which one? black07cs 2005 - 2010 3 December 8th, 2007 10:27 PM
Crank pulley bolt? 88gtstang 5.0 Mustangs 3 March 9th, 2007 11:23 PM
