quick question on TOB noise vs gear whine
Old September 30th, 2008, 08:23 AM   #1
coffinator6's Avatar
03 GT, 92 coupe 2.3T
coffinator6 will become famous soon enough
im looking at an 02 manual coupe to buy. when i let off the gas and it coasts or i accelerate it makes a whining/grinding noise. my first thought was the tob but he said he just replaces the pinion seal and i thought maybe he didn't re-preload it right.
can someone explain the difference on how i can tell by the sound and when it happens.
the car does feel like it has an aftermarket clutch in it but the owner bought it like that. he is not the origional owner.
Old September 30th, 2008, 08:41 AM   #2
Moderator
TOB noise can also change when you disengage/engage the clutch.
Chances are if the noise wasn't there before the pinion seal was replaced, that it's gear whine.
Old September 30th, 2008, 09:45 AM   #3
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
+1 ^
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Threads Similar to: quick question on TOB noise vs gear whine
4.10 gear whine ivan48humble 2005 - 2010 7 July 27th, 2008 04:34 AM
Gear Whine 06Black5spdGT 2005 - 2010 21 July 26th, 2008 03:42 PM
gear whine??? 06SuperStang 2005 - 2010 15 June 9th, 2008 06:47 PM
Gear Whine? DanTheMan 99-04 30 December 10th, 2007 07:32 PM
gear whine? 94v6blkndred V6 Mustangs 5 July 6th, 2007 12:44 PM
