Fu&%#ing ABS light keeps coming on and off
LinkBack (2) Thread Tools
Old September 30th, 2008, 11:41 AM   2 links from elsewhere to this Post. Click to view. #1
Profeta's Avatar
2003 Mustang
Profeta is on a distinguished road
Hey guys I am fed up with the dawm ABS light coming on and off. I took it the mech and he said there is nothing wrong with the brakes is just a sensor but the fucking light is driving me insane can anyone tell me how to fix the shit..
PS: Sorry for the language I needed to vent..LOL
MILITARY CREW
USMC/SGT
Old September 30th, 2008, 11:54 AM   #2
CNASHGO's Avatar
2005 Ford F150 FX4
CNASHGO is on a distinguished road
Send a message via MSN to CNASHGO
you could replace the sensor
2005 Ford F150 FX4-New Toy
MM Truck Crew
2002 Ford Mustang V6-Sold
1997 Ford Mustang V6-Sold
Old September 30th, 2008, 12:13 PM   #3
Profeta's Avatar
2003 Mustang
can you tell where the sensor is and how to replace it?
MILITARY CREW
USMC/SGT
Old September 30th, 2008, 10:59 PM   #4
CNASHGO's Avatar
2005 Ford F150 FX4
I believe there is a sensor just behind each wheel. there should be what looks like a gear that spins with the wheel and the sensor monitors when each tooth on the gear comes around.
http://arrc.epnet.com/autoasp/framerq.asp
never mind that site will only work if you have my user name and password
MM Truck Crew
Old October 3rd, 2008, 08:39 AM   #5
Mywhite00gt is on a distinguished road
ABS Sensor on
The sensor should be attached to the hub assembly/wheel bearing behind the rotor- you might want to check the wheel bearing as well usually the ABS sensor going bad goes along with a bad wheel bearing/hub assembly
it sells as one unit sensor and hub assembly(as far as I know)
Old October 4th, 2008, 12:41 AM   #6
snoel123 will become famous soon enough
There is a sensor at each front wheel. All solid axle abs equipped mustangs have on on the top of your differential housing. You need to pull the code to find out which sensor is faulty. Sometimes all it is is the rear diff sensor has metal filings on it and it is contaminating the sensor. Also note all IRS mustangs have sensors at each rear wheel. Be aware that it can also be wiring, tone ring and module issues. Just throwing sensors at it can turn out costly. Get the code read, post the number and I can tell you how to diagnose it. Hope this helps you.
Certified Master Technician
Also FORD certified
-Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist.
Old October 4th, 2008, 10:04 AM   #7
coffinator6's Avatar
03 GT, 92 coupe 2.3T
coffinator6 will become famous soon enough
thats funny because my sensors on my 01 are at each rear wheel and not in the center.
to the op. they are super easy to replace on the rear. just takes a 7mm or 8mm socket. loosen the bolt and pull the sensor straight back while turning it back ant forth. it shouls slide right out. then disconnect it. reverse the last steps for install. I'm not sure but after install you might have to go through a sequesnce so that car understands that there is a new sensor. I know some cars require that, but im not sure if the mustang does. i have had mine unbolted to remove the axles but never unplugged.
Old October 5th, 2008, 12:01 AM   #8
Maybe they are two on the rear of solid axle mustangs. Don't work on abs with mustangs too much (they don't see corrosion and wear like the trucks.).
Anyway it doesn't matter if you change all 4 sensors because of an abs light, you might as well burn up 400 bucks. Your abs light can be on from a wiring problem , module problem, relay problem, network problem etc. But hey if you want to throw away money go ahead and change all the sensors.
Also FORD certified
Old October 5th, 2008, 12:05 AM   #9
Heres the codes that turn on abs light
| DTC | Source | Action |
| C1095 | Hydraulic Pump Motor Circuit | GO to Pinpoint Test F. |
| | Failure | |
| C1145 | RF Anti-Lock Brake Sensor | GO to Pinpoint Test B. |
| | Input Circuit Failure | |
| C1155 | LF Anti-Lock Brake Sensor | GO to Pinpoint Test C. |
| C1165 | RR Anti-Lock Brake Sensor | GO to Pinpoint Test D. |
| C1175 | LR Anti-Lock Brake Sensor | GO to Pinpoint Test E. |
| C1194 | LF ABS Outlet Valve Coil | REPLACE the EHCU. |
| | Circuit Failure | |
| C1198 | LF ABS Inlet Valve Coil | REPLACE the EHCU. |
| | Circuit Failure | |
| C1210 | RF ABS Outlet Valve Coil | REPLACE the EHCU. |
| | Circuit Failure. | |
| C1214 | RF ABS Inlet Valve Coil | REPLACE the EHCU. |
| C1222 | Wheel Speed Signal Mismatch | GO to Pinpoint Test G. |
| C1233 | LF Speed Signal Missing/Failed | GO to Pinpoint Test C. |
| C1234 | RF Speed Signal Missing/Failed | GO to Pinpoint Test B. |
| C1235 | RR Speed Signal Missing/Failed | GO to Pinpoint Test D. |
| C1236 | LR Speed Signal Missing/Failed | GO to Pinpoint Test E. |
| C1242 | Rear ABS Outlet Valve Coil | REPLACE the ECHU. |
| | Circuit Failure | |
| C1250 | Rear ABS Inlet Valve Coil | REPLACE the ECHU. |
| | Circuit Failure | |
| C1266 | ABS Valve Power Relay Circuit | REPLACE the anti-lock brake |
| | Failure | control module. |
| B1318 | Battery Power Low | GO to Pinpoint Test A. |
| B1342 | ECU Defective | REPLACE the anti-lock brake |
| | | control module. |
| B1596 | Service Continuous Codes | REPAIR DTCs retrieved. |
Also FORD certified
Old October 5th, 2008, 12:10 AM   #10
Oh yeah you can clear codes and reset KAM (Keep Alive Memory) once you correct the problem to get rid of the abs light. If it is a sensor issue that is repaired upon replacement just drive the car if no scan tool is available. Once the speed signals are all synchronized again (after a few kms) the computer will turn the light off but keep the dtc as a CMDTC (continuous memory diagnostic trouble code) until KAM is reset.
Also FORD certified
Old October 5th, 2008, 08:30 PM   #11
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of97S281 has much to be proud of
iTrader: 18 reviews
mine was a wire that was disconnected before i bought it. all they had to do was reconnect it and all was well. I wouldn't go replacing shit until you verify the problem, otherwise your just pissing money away.
MODS IN GARAGE
All SVO'D UP
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/90915-fu-ing-abs-light-keeps-coming-off.html
Intermittent Abs Light This thread Refback December 9th, 2012 03:20 PM
abs trouble code c1210 This thread Refback December 4th, 2010 07:39 AM
Threads Similar to: Fu&%#ing ABS light keeps coming on and off
abs light efulton95 94-95 6 June 17th, 2008 12:07 PM
abs light Graytex 96-98 3 March 20th, 2008 11:24 PM
ABS Light MustangMatt96GT 96-98 15 September 2nd, 2007 06:52 PM
ABS light j2000_guy 94-95 3 March 29th, 2007 12:42 PM
ABS Light GT 849 99-04 17 November 25th, 2006 12:57 AM
