ALT Problems....Help
A few days ago I devloped a problem....I was driveing along and my battery light started going nuts. Blinking randomly. I check all my connections on my battery and the ground. All looks good to me! It has a new battery and it's 3rd new alternator within a year. At first I thought it was my belt sliping because I was driving it kinda hard and it could be replaced im sure. But i replaced the belt and now It even did it at an idle. But then went away for a few then came back agian.
Then a few days went by and every thing was fine. Any ideas? I have UDP....they have been on for two years and never had an issue before. Clif Notes... -BAT Light freaks out and and the gauge looks fine and dosn't move. -All Conections are good at the battery. Brand New BATT and ALT less then 3months old. (4th one this year) - I do have underdrive pullies! Will using the Orgianl pulley on the ALT stop this from happening like every 3 months? -I know this means my ALT is going bad. But how can i prevent it? HELP
2000 Ford Mustang GT 5spd (TOY) 1997 Ford Tunderbird LX = Daily Driver Last edited by gt_andy; October 1st, 2008 at 11:17 AM. |
2002 GT
99.99@999.9
sounds like you alt is going out, mine did the same thing, and it overcharged and the post on top melted and fried my wire.
2002 GT
99.99@999.9
and UDP shouldnt cause a prob, what kinda belt do you use? gatorback FTMFW
#4 | |
This is the 4th time this has happend. I know my ALT is going out! I trying to find a way to prevent it from doing it agian. I have UDP's, Could this be causin the ALT to go out. If so, what can i do to prevent it without losing my UDP's? Can i keep the stock pulley on the ALT?
2000 Ford Mustang GT 5spd (TOY) 1997 Ford Tunderbird LX = Daily Driver |
#5 | |
2002 GT
99.99@999.9
could be a ground wire, check all your wire for corrosion, tears, loose connections. also load test your batt
sorry i just reread your post, and you checked the wires, the only thing i can think of is to recheck, and rerecheck all your grounds, and you said the batt is new, i would still take it to autozone and make sure its still good to go. as for the UDP's iv never had probs with them.
Proud American
try a high amp altinator. PA performance ftw
2002 GT
99.99@999.9
yea the stocker is 190 isnt it?
#8 | |
Do you have a link? About how much do they run?
---------------------------------- I belive i just gonna get a new one and leave the Stock pulley on it and get a smaller belt. We will see how that works
2002 GT
99.99@999.9
wow. expensive.
It's back
Threads Similar to: ALT Problems....Help
| alt/battery problem | 90blowngt | 5.0 Mustangs | 6 | September 6th, 2008 12:27 AM |
| Alt ???? | CBSTANG | 99-04 | 5 | August 18th, 2008 06:02 PM |
| alt question | noob24 | V6 Mustangs | 7 | January 8th, 2008 06:07 PM |
| PI alt. bracket? | caintcatchmyGT | 96-98 | 11 | September 7th, 2007 02:35 PM |
| 3g alt. upgrade | 91foxhatch5.0 | 5.0 Mustangs | 12 | July 18th, 2007 09:42 AM |
