Discussing Springs Installed, Simple Question in the 99-04 Forum. Instead of getting into details, I'm gonna get straight to the point. H & ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#1 | ||
2001 Ford Mustang Bullitt
H & R Super Sport Spring 96-04 - Installation Instructions at AmericanMuscle.com
Also:
Lastly, people always say to get lower and upper control arms. Doesn't the Mustang GT already have them? I'm GUESSING they mean to replace the stock ones? Thanks!
![]() Current mods:
MM Bullitt Crew Member #1
2000 mustang gt
11.79@115.83
dont worry about the twisting and binding, if everything bolted up just fine then your are set. the twisting they are talking about is the axle moving and it can be a pain to get it back to the way its suppose to be. and yes they mean replacing stock arms.
stock long block, bolt ons, slicks, and a little squeeze N/A-12.81@103.7 N2O-11.79@115.8 parting out 04 cobra, pm me for details |
#3 | |
Awesome, reps headed your way!
Now, why does it say to do one side at a time? It even has an exclamation mark, so it must be serious! Lol, for real though, it has so much enthusiasm on that part, what gives?
![]() Current mods:
2000 mustang gt
11.79@115.83
it keeps the axle from moving, dropping, limits the twist, etc.
So since I'm done, and the rear is in, nothing is messed up? How could I check if I did something wrong?
Also, I'm hearing a scratching noise in the front driver side. It sounds like grabbing a piece of metal and dragging it across concrete. I can hear it driving like 10-20 MPH and more, but as long as I let off the gas - because my exhaust would drown it out otherwise. So lets say I'm rolling neutral, I can hear it, and it's not one long scratch that keeps on going, but it's more as if it's doing it in intervals like within a second or two of each other. It's kind of hard to explain, I wish I had a camera. On the front I reused the stock bottom isolator because I couldn't get the new ones to fit, nor the old top one to fit. I DON'T hear that scratch on the passenger side.
![]() Current mods:
Dammit, I can't edit my post after 15 minutes. The reason I mentioned the fact that I didn't install the top isolator was just to let you know, because possibly that could be the culprit, but since I don't hear it on the passenger side, I just wanna hear your opinion.
![]() Current mods:
2008 GCSRT8, 1965 Coupe;
thats why they are there... but yeah springs arnt that bad to put on... LCA's arnt either but my bolts on the axle side was pretty seized up... had to beat on them some
13.00 @ 105
did you take your brake calipers off of the fronts? It may be the pads rubbing on the rotor
We took off the brake pads on both the driver AND passenger side, but on the driver side we took off the rotor as well. Well, next week I'm gonna install the isolators, lift the front up a little. It looks weird because the front is so low and the rear isn't. Hell, I didn't just spend $25 on some front isolators to not reuse them! I don't wanna sell them either lol. Anyway, while I'm under there, is there anything else I should check? You say to check the brake pad rubbing against the rotor, where exactly would it be rubbing? My other friend also to me to check the dust shield, make sure it's not bent, and if it is, just straighten it out. Thanks!
![]() Current mods:
13.00 @ 105
it could be the dust shield... if I heard the sound it would be much easier to diagnose...
If it is the pads rubbing, how did you compress the pistons to get the pads back in?
They just slid right in lol.
![]() Current mods:
13.00 @ 105
i would just about put my lunch money on it being a dragging pad
Just wanna make sure, by dragging pad you're talking about the brake pad, right? What exactly would it be dragging against, the rotor correct? Isn't the pad supposed to be around the rotor? So how exactly would it drag? And is it bad if I don't fix it? I will fix it next week on Wednesday, but I'm just curious, thanks!
![]() Current mods:
13.00 @ 105
the brake pads should have just enough space between themselves and the rotors not to constantly drag, until you hit the brake pedal. If they continuously drag, you run the risk of ruining the pads and/or making them wear down pretty fast. If they drag pretty hard, you run the risk of getting the rotors and brakes getting so hot that they catch fire
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
I'll bet my lunch money its the dust cover. They're really flimsy and you could bend one without knowing it.
#16 | |
13.00 @ 105
13.00 @ 105
what ended up being the problem?
Oh sorry I forgot to post up, it was the dust shield lol. When I was originally working on the driver-side spring, my hand slipped when I was wrenching one of the bolts and scraped my arm on the dust shield, that might of done the trick
. Anyway, that annoying sound is gone, and my isolators are installed, my car isn't as low, and I don't scrape on every speed bump, hurray for me!
![]() Current mods:
13.00 @ 105
good news... easy fix!
If I already had the isolators installed, and I knew for sure the dust shield was the problem, I could of just stuck my hand through the wheels and fixed it without taking them off lol.
![]() Current mods:
Threads Similar to: Springs Installed, Simple Question
| Simple question... | AnglicoGT98 | Poweradders | 7 | January 24th, 2008 12:29 AM |
| very simple question | Murderjetz | V6 Mustangs | 22 | August 14th, 2007 08:30 PM |
| A Simple Question: | WAR-PARTY | The Clubhouse | 16 | June 30th, 2007 02:48 PM |
| Simple question | 8A_Honda | 5.0 Mustangs | 2 | June 17th, 2007 11:12 AM |
| Simple question... | 2000Mustang | V6 Mustangs | 37 | April 13th, 2007 10:08 PM |
