91 Octane Tune?
LinkBack (1) Thread Tools
Old October 2nd, 2008, 06:32 PM   1 links from elsewhere to this Post. Click to view. #1
2001 Mustang GT
GTSilverBullit can only hope to improve
Send a message via AIM to GTSilverBullit
91 Octane Tune?
I posted the thread on a dyno tune, but now im wondering what Octane to tune for? I use 91 octane from chevron right now, cause thats all we have where i live, its really good gas...
Ive read around that the 91 octane at chevron is equivalent to others' 93 octane, is this true? and if so, would i need to tune for 93 octane?
Old October 4th, 2008, 10:48 PM   #2
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
The octane ratings applied to pump gas are very well documented and regulated--irf it could pass the 93 octane standards you can bet they'd call it that...
That said however most handheld and otherwise "end user configurable" tuners are very conservative in their timing settings (most just add 2.0° regardless of what octane you select, change the closed to open loop delays to 0 s, and richen up the stabilised open loop AFRs a bit).
If you have a global WOT setting on your tuner then add 2° and listen for pinging--you probably won't have any so go for 2.5° and listen again...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old October 5th, 2008, 09:29 PM   #3
2001 Mustang GT
so then i would have to dyno tune for the timing right?
Bassani Catted X-Pipe
Magnaflow Catback
JLT CAI
MGW Short Throw
Sportline 1.5" drop
Falken Torque-5 18X8 wheels
"Magna Cum Laude"
[SIGPIC][/SIGPIC]
Old October 6th, 2008, 04:38 AM   #4
cliffyk's Avatar
You don't ever have to "dyno tune" if you have sufficient experience with tuning, or if you are willing to work at gaining such experience.
There is no magic involved in utilising a dynamometer to tune an engine, all it does is make it convenient for someone tuning cars for a living because they can do it in one place and have some immediate feedback on the effect of their changes. That's it, it's just a measuring tool that really doesn't have a damned thing to do with the tune itself...
Also, because "dyno tunes" are not done under real on the road conditions (airflow and temperature are the two biggest challenges) they really just represent starting place for further tweaking for anyone that's serious about getting their ride fully dialed in.
-cliff knight-
My Mustang
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/91249-91-octane-tune.html
91 Octane Tune? This thread Refback October 6th, 2008 05:05 AM
Threads Similar to: 91 Octane Tune?
93 octane tune killermach1 2005 - 2010 8 August 21st, 2008 11:00 PM
93 octane tune guys adrenaline=lifeline 99-04 18 July 31st, 2008 12:57 AM
octane and TUNE kennyGT 96-98 2 July 8th, 2007 12:20 PM
89 octane tune leebunnyz 2005 - 2010 1 May 31st, 2007 11:34 PM
87 vs 93 octane tune 99v6stang V6 Mustangs 18 April 21st, 2007 04:31 PM
