Input shaft bearing or the TB
Recently i did a clutch job on my 2002 GT. centerforce dual friction, centerforce TB and pilot bearing. When i took the car and drove home i noticed a rattling noise when i was in nutral. Like metal on metal rattle. When i press the clutch half way it goes away (where the point of engagement). If i press slightly on the clutch the noise doesnt go away.
The guy told me that its the TB resting on the pressure plate resulting in this rattle. the fix is a Steeda cable adjuster kit. If its cold mind you it doesnt do it. when i drive for like 15 minutes it starts. Also i can still hear it in all gears specialy first and second. Plus when i press the clutch pedal all the way in and release sometimes the noise dont appear right away. Now another mechanic heard the noise and told me it has nothing to do with the clutch cable and the TB but its my input shaft bearing that is bad. Do i need both or one of these fix. Regards |
My clutch does the same thing, except all the time
,go with the adjuster kit. That is what I will be doing
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3. |
Threads Similar to: Input shaft bearing or the TB
| shims for 26 spline input shaft T56?? | killerSVTcobra | 4V / SVT | 8 | October 1st, 2008 10:35 PM |
| Output Shaft Bearing? | Hunt_chevs | 5.0 Mustangs | 2 | September 26th, 2008 01:30 PM |
| which is better liberty or d&d 26 spline input shaft | killerSVTcobra | 4V / SVT | 1 | August 27th, 2008 05:45 PM |
| drive shaft shop one piece steel shaft ok for automatic tran | mustang fanatic | 2005 - 2010 | 8 | September 24th, 2007 01:21 AM |
| input shaft prob | shadowgames81 | 5.0 Mustangs | 1 | May 18th, 2007 11:33 PM |
