romeo or windsor
Old December 7th, 2006, 09:53 PM   #1
TrueBlueGT01 is on a distinguished road
romeo or windsor
11 valve cover bolts on mine(romeo). 8th digit of VIN =X (windsor). Born on 3/14/01 after 2/22/01= considered 01 1/2 through 04 era. Looked under 5m trans and drain bolt straight down=T3650(upgraded T45) ......... Do I have 6 bolt flywheel? Do I have 11" clutch? Which upgraded heads do I need? I am currently assembling parts pile for teardown and rebuild for real power but dont want it down for too long. Thanks for the help.
Old December 7th, 2006, 11:44 PM   #2
Drgnracin72's Avatar
well it s amodular motor so everything will work together except for the clutch and flywheel. if you have a 11 bolt valve covers you have romeo heads, but your block can still be a windsor blick. ford mixed and matched everything and its confusing as shit sometimes but will all work together
just piecing it together is the hard part
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old December 8th, 2006, 02:21 AM   #3
superbeef1000's Avatar
well if its a winsor block it should be an 8 bolt fly wheel
Old December 8th, 2006, 09:46 PM   #4
I was under the assumption that windsor interchanged only with windsor, and romeo with romeo. Huh. thats cool that it all interchanges. So I guess its all good.Does the X in VIN indicate windsor mean it is a windsor block = (8 bolt crank). If I had 4v heads off of late 90's cobra will they work with 2v block? Thanks for the help.
Old December 9th, 2006, 10:31 PM   #5
the way i understand it the cobra block is just a modified romio block with 8 bolt crank and prolly some other mods done to it ,,it may need to be machiened to get them to fit ,,,, if thats rite at all
Old December 10th, 2006, 01:26 PM   #6
i have a romeo block with a windsor set of heads
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: romeo or windsor
romeo or windsor mystang0673 99-04 31 November 25th, 2011 09:34 PM
which one to have Romeo or Windsor shamntgmry 99-04 75 October 18th, 2007 09:33 AM
romeo or windsor energiesource 99-04 1 September 29th, 2007 01:59 PM
romeo vs windsor? mystang0673 99-04 0 March 5th, 2007 11:52 AM
11 bolts = romeo or windsor niubodybuilder05 99-04 4 December 6th, 2006 07:19 PM
