Help with Axle please
Old October 5th, 2008, 01:41 PM   #1
John's_stang is on a distinguished road
I posted earlier about bending my axle.. now i need help on how to remove the axle shaft to replace it...
ive heard all you have to do is remove 4 retaining bolts and the axle should slide out...
but idk where the 4 bolts are? help?
Old October 5th, 2008, 01:54 PM   #2
01gtMustang132's Avatar
2001 Mustang GT
13.15@101
01gtMustang132 is on a distinguished road
put car on jack stands or lift first...
Remove tires...
Remove brake assembly...
On a 8.8 take the rear cover off...
Spin the diff so you can get to the pin retainer bolt...
Take it out and remove pin...
Then push in on axle take off c-clip inside diff...(both sides)
Then remove axles...
Install is opposite of removal...
Old October 5th, 2008, 06:20 PM   #3
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Also, and if you have ABS, remove the ABS sensors before pushing the axles in to remove the C-clip. If you do not there is a good chance the sensors will be physically damaged...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Threads Similar to: Help with Axle please
Axle help sjr56 99-04 3 July 5th, 2008 12:10 AM
what axle do i have?? badf150boy123 99-04 1 April 1st, 2008 08:47 PM
I GOT MY AXLE!! Bies08 V6 Mustangs 21 July 9th, 2007 07:01 PM
Need help on GT Axle Bies08 99-04 4 July 8th, 2007 05:46 PM
05 v6 axle ? meogge V6 Mustangs 1 December 3rd, 2006 07:09 PM
