Discussing Taking off Stock catback in the 99-04 Forum. I just got my Magnapacks. But i want to keep my stock catback and get ...
Old October 7th, 2008, 07:47 PM   #1
PowerShiftz02GT's Avatar
I just got my Magnapacks. But i want to keep my stock catback and get it off in one piece. I heard this is impossible and you will need to cut through the piping. I also heard if you have a Lift you can get the catback off just fine. So which one is true? I have access to a lift but not sure when i will be able to use them. So if i can do this myself the sooner ill be able to put my new exhaust on.
Also my muffers are welded in. Not sure if that matters. Previous owner this. So is this a problem?
thanks
-5-Speed
-BBK CAI
-UD Pulleys
-BBK 70MM TB
-Mac O/R H pipe
-Trick Flow Plenum
-Yokohama AVS ES100 Tires
-UPR Blue Thunder Short Throw
-Magnaflow Magnapack Catback
Old October 7th, 2008, 07:51 PM   #2
ajm
Jack the car up the in rear. Put the stands where the rear lower control arms connect to the unibody. This should allow for your axle housing to drop down away from the car. if that doesnt give you enough room remove shocks etc to drop it low enough.
Old October 7th, 2008, 08:50 PM   #3
casper gt's Avatar
2000 mustang gt auto
13.75@100
only way to get off a welded exhaust is to drop the rear axle (with out cutting that is )
2000 gt auto
Old October 8th, 2008, 03:45 PM   #4
ic. so how is it stock? the stock mufflers are bolted up?
-5-Speed
-BBK CAI
-UD Pulleys
-BBK 70MM TB
-Mac O/R H pipe
-Trick Flow Plenum
Old October 8th, 2008, 04:09 PM   #5
03gtfirered's Avatar
2002 MUSTANG GT
just cut them both in the same spot and then you can use clamps to reinstall if necessary.
______________________________
first time stang owner and loving it!!!
SlP lm2's, pypes o/r x pipe, jlt intake, mach grill delete, tinted headlights and tail lights!!
I got the modding bug.....
Old October 8th, 2008, 04:16 PM   #6
DiZzyBonne's Avatar
2001 Ford Mustang Bullitt
The stock exhaust setup is as follows:
Exhaust manifold -> screws -> H-pipe -> screws -> catback (mufflers and tubing that runs over the axles)
So what happens is after unbolting the catback, you have no way of snaking it out unless you drop the rear axle. I simply cut mine off with a Sawzall. I was like, later bitch!
Current mods:
  • Maximum Motorsports XL Full Length Subframe Connectors
  • Catted Bassani X-Pipe
  • Borla Stinger Catbacks
  • H&R Super Sport Springs
MM Bullitt Crew Member #1
Old October 9th, 2008, 10:39 PM   #7
ok thanks guys. i got it off. i just cut them right before the muffler. oh well.
-5-Speed
-BBK CAI
-UD Pulleys
-BBK 70MM TB
-Mac O/R H pipe
-Trick Flow Plenum
Old October 9th, 2008, 10:42 PM   #8
yojoe600's Avatar
way do get the best sounding exhaust
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
2004 GT FOR SALE
http://www.moddedmustangs.com/forums...tml#post927678
Cat Club Co-Founder
Threads Similar to: Taking off Stock catback
taking off stock head unit? PowerShiftz02GT 99-04 2 June 26th, 2008 09:56 PM
99-04 gt stock catback competition orange Exhaust 1 February 21st, 2008 10:28 PM
WTB 99-04 Stock catback JaxnsGT Want to Buy 8 February 19th, 2008 02:08 PM
Taking off stock Air filter housing RandoGT Engine 6 August 3rd, 2007 03:20 AM
Taking off Stock intake manifold 95blueGT 94-95 9 June 18th, 2007 10:50 AM
