Discussing Where could it come from? in the 99-04 Forum. ive noticed alot of oil underneath the lower plenum, and it seems that im losing ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2000 Ford Mustang GT
14.41
ive noticed alot of oil underneath the lower plenum, and it seems that im losing enough oil to have to add some before i do a regular oil change. step dad said valve cover gasket, but just wanted to know if anyone else had the problem or knows of any other components it could be in that area.
![]() K&N intake, Diablosport predator, Steeda Underdrive pulley set, Steeda Tri-ax, SLP Catted X-pipe, Flowmaster 50 series DeltaFlow's, Sumitomo HTRZ+ 255\45\17's, Pro Products Plenum\70mm TB kit. ^^^^^ Gone, but i miss her
1999 Mustang GT
if its losing that much that may be good place to start looking. you ought to be able to tell from exactly where its coming from as well. look for a spot that has collected some dirt if your motor is fairly clean.
Id start with the valve cover gaskets as well. Cheap and easy.
14.41
well thats the thing, no oil leaks under the car, no sludge anywere on the bottom, just that spot. and the oil dosent seem burnt on,just dirty.
Could you take a pic and circle the area in paint or something just to give a little more detailed description of where its coming from? How many miles on the car and such?
14.41
this isnt the exact motor, this is from a 97 repair manual, but i think you can get the picture. the area below the Intake
![]() The area fill in with black
#7 | |
2002 GT
99.99@999.9
14.41
yes, i thought the intake manifold was reffured to as the lower plenum seeing there is an upper plenum
#9 | |
2002 GT
99.99@999.9
it might be, but i call it the intake manifold. anywho, i get alot of oil in TB and it would pool in the bottom of the intake manifold. It came from the PCV system on my car, but after i rebuilt it and put a catchcan in the system it stopped, so it could be comming from that, but there would be a hole in the bottom of the intake manifol, and that would be showing its on symtoms, i really cant think of anything other than 1: valve cover gasket (but you said you checked that) 2: could you have spilt oil on an oil change? iv done it, weve all done it before, hell iv dropped a whole quart of oil on my motor lol i would wash/clean that oil up and check it everyday and see if you can track it down |
My car did the same thing once upon a time - never could figure out where the he11 it came from.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
2002 GT
99.99@999.9
i might be fucking something up, but iv never had a car that produced so much oil from the PCV system like my mustang does, take the intake manifold off and find were its coming from, the intake manifold isnt hard to take off, just make sure your motors cold and you follow your lossining/tightning sequences and torque specs when you put it back on, and get an intake maniflod gasket befor you do it, mine tears up everytime i take mine off
seriously, what the dilly? Freaking turds LOL.
2002 GT
99.99@999.9
yea man iv talked to some cats on here and they said thats just the way it is
