best /cheap traction mods
i finnally launched my car with the 390's,and i cant get traction at all,I even peel out in 2nd gear,after ive hooked in first grear,and this is after ive heated up my tires,my street tires have alot of tread left ,so im not ready to get street dr's,so what are the best/cheap suspension mods i can get,I was going to get a tuner but whats the point if my car cant hook,
All the mustang guys around here launch with there TC on then take it off when they hit second,I havent tryed it but they say it works real good,wouldnt that bogg ur car down
[2000 blue mustang gt vert 5spd,stalker bodykit,18'' cobra rims,lowered 2'',light bar,k&N cai,roush side exhaust,x pipe,pp 75mm tb & plenum Pro5.0 3:90 gears,Custom 91 octane SCT tune 2000 red VW jetta,auto stockTopless Mustang Club Member |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Correct about the traction control chances are its gonna screw you it will sense that the wheels are spinning too fast or 1 wheel is spinning too fast vs the other. It will then make adjustments to your engine to compensate for the problem it reads meaning lowering your rpm and applying the brakes to both or the needed side. As for the mods ill leave that up to everyone else. Im not going to say "GET THIS" or "GET THAT" to have you get something youre disappointed with. In my opinion go with what you think is best. Not everyone else.
In my opinion go with what you think is best. Not everyone else.[/QUOTE]
i dont no what to get thats my problem,i bought my firebird with a bunch of suspension mods already on it,so i never really had a problem hooking with that car, As far as the TC,when ever i complain about traction the mustang guys i know just tell me to hit the magic button when i launch,i never tryed it,
KB'd GT
I would never use TC for anything performance related. Thats only for old women who don't know how to drive a mustang in the rain. Maybe try shocking the tires less with a low rpm dump/ slip.
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
you could lower the tire pressure im not to sure how much this helps with street tires if at all.. but then you have things like upper and lower control arms, and i think there are launch springs that might help aswell..
![]() i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day. why? because it would be fucking AWESOME.[/quote] |
Heres my opinion...Not telling you what to do as you said in the first post this is just what id do. Tell them to shuv their "little magic button" leave the TC off. What I explained in the first post is how traction control works. Tires spin to fast, computer makes adjustments to compensate for tires spinning too fast, those adjustments are 1. bog down engine 2. apply brakes to both or the side spinning faster. Second if I were to build up my rear suspension id go buy some upper and lower rear control arms which are fairly cheap, some good shocks, and springs. Springs being last and control arms & shocks being bought at same time.
my advise is free... dont lace into it so hard, just get as heavy into the pedal as you can before it breaks loose. you have to find that happy medium where you are on the verge of spinning but just grabin pavement
ajm... does TC actually apply the brakes as well?? im assuming through the ABS system
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
#8 | |
2001 Mustang GT
13.15@101
Unhook the front sway bar when you go to the track...
I've seen people gain 2 to 3 tenths... And it pops the noise in the air to put weight on the rear... A friend of mine had the sway bar hooked up and was spinning... Then unhooked it and broke the axle... So be careful if you have stock axles... |
#10 | |
2002 Camaro SS
12.XX@11X??
![]() iTrader: 1 reviews
2006 GTO A4-13.3 2.1 60' Motor/12.0 1.7 60' 100 Shot otherwise stock |
13.00 @ 105
depending on what you consider "cheap"... the sway bar trick works... but for ~$500 you can get a set of nice control arms and subframe connectors and it would help tremendously
#12 | |
Zoolander
04 Cobra #2260/3768 1/820
2004 mustang GT
would subframe conectors help his problem? or are they more for body roll in corners?
flowmasters, no cats, 3.73's, sct xcal2, eibach pro kit, CC plates, 75mm TB, plenum, T56 Cobra manual transmission,and last but not least a procharger P1SC. 400hp and 376ft-lbs |
13.67 @ 99.3..5000 ft D.A.
just get some tires for track use only...
nothing will make a bigger difference than a set of sticky tires
2000 Mustang GT- 4.10's, Hoosier DR's, JLT, 75 mm TB, Plenum, MAC LT's, VRS O/R X-pipe, MAC Catback 13.671 @ 99.11 (1.80 60') 5000+ ft above sea level - in El Paso, TX http://www.youtube.com/watch?v=U2l4JdEg3hg
13.00 @ 105
it will make the weight transfer a little more evenly to the rear and less body roll like you said
They keep your body from twisting in hard acceleration. Nothing to do with body roll. Your suspension controls body roll. They will help with your launch though.
Admanistrator
get tlok.
2008 GCSRT8, 1965 Coupe;
ive heard that it controls fuel, spark, and the brakes... and ive felt it kick my ass end around before...
amateur adult film star
lower and upper control arms draglaunch springs
![]() ![]() performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
Sorry, I was talking about at launch it won't apply brakes. It will apply brake if one wheel is spinning faster than the other at higher speeds, and not at WOT. At launch they will be spinning the same, and it will only cut the throttle and spark.
Threads Similar to: best /cheap traction mods
| cheap mods | 2000roush | 99-04 | 9 | March 24th, 2008 02:51 PM |
| any cheap diy mods? | texas_mustang | 2005 - 2010 | 65 | September 16th, 2007 12:09 AM |
| cheap mods fo more power | black stang | General Tech | 7 | May 8th, 2007 05:00 PM |
| cheap power mods for 95 V6 | 95kystang | V6 Mustangs | 47 | March 20th, 2007 10:31 PM |
| Cheap Mods | Michael | Modular Mustangs | 17 | November 15th, 2006 03:32 AM |
