Discussing new zex kit in the 99-04 Forum. i just bought the zex wet kit from americanmuscle and was wondering how hard it ...
Old October 9th, 2008, 04:40 PM   #1
2004 mustang gt
new zex kit
i just bought the zex wet kit from americanmuscle and was wondering how hard it is to install and how off my tune would be after i got it tuned for cams and what are the exact spark plugs i should run thanks in advance guys
2004 mustang gt-
bbk cai, bbk 75mm tb, bassani o/r x-pipe, magnaflow catback, stage 2 cams, 315 nitto 555, steeda tri-ax, zex 100 wet shot
Old October 9th, 2008, 04:57 PM   #2
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
me and my dad put my nitrous kit in by ourselves. Is yours a wet kit? Dry kits are a little simplier cause you dont have to fuck with fuel lines or that extra fuel syllonoid. The best advice i could give you is map everything out first. Decide where your putting all your syllonoids, where your running your piping, making sure you have enough room cause those 4an lines dont bend very well. Other than that, its def something that shouldnt take you more than a weekend, if that long. As far as the tune goes, if you have a handheld programmer, i dont think it would be very hard to get them to upload you a nitrous tune ontop of your cammed tune. If its like a custom ecu tune or dyno tune, that a different story.
Somebody registerred me at blacksingles.net
www.ccasr.org <---- click it, i dare ya
Old October 9th, 2008, 05:07 PM   #3
2004 mustang gt
its the zex wet kit with the little box that holds the noids and stuff but yea its a dynotune from houston performance
2004 mustang gt-
Old October 9th, 2008, 05:16 PM   #4
2004 Mustang V6
14.4@ 96
ooo, i forget thats how zex does it, i really wish thats what i would have gotten. But then it should be an even easier install. Tune questions should be answer by someone with more experience than me, i only have a tuner with a nitrous tune.
Old October 9th, 2008, 05:24 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
If your tune is like a 93 octane tune then you will have to back out some timing for the spray, and you will need a 1 stage colder plugs for a 75-100 shot. you need to find out how much timing they advanced then go back to that much plus back 1-2 degrees.
Gone To Basic Training
Old October 9th, 2008, 05:56 PM   #6
2004 mustang gt
yes its a 93 tune and i guess ill just have to talk to houston performance then about the tune maybe get anothr dynotune? also how would i know the plugs are a stage colder and one more thing will the new tune mess up the way my car is with the cams. thanks so much yall sorry about so many questions
2004 mustang gt-
Old October 9th, 2008, 06:21 PM   #7
2004 Mustang V6
14.4@ 96
they are rated, like tr5. I just cant remember if the higher number means hotter or colder. I think tr5 is colder than tr6.
Old October 9th, 2008, 09:13 PM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
No its the other way. I ran NGK TR6's with my 100 shot and no tune at all. Now I run TR55's for my N/A setup. NGK is all I run but some guys just run champions and some guys just run other brands. its alot like mufflers. Just don't run platinum with boost or spray, platinum doesn't bend, so under high boost instead of bending or warping it just flat breaks off and then you are in a world of shit. For me its TR6's for boost and spray and TR55's or if you wanna drop big bank for Iridium then ITR5F13's for N/A. For NGK the higher the number after the R the colder it is. here is a link for the heat ranges overview.
NGK Spark Plugs USA
Old October 9th, 2008, 09:24 PM   #9
2004 Mustang V6
14.4@ 96
thanks for clearing that up doc, ill have to bookmark this. reps+
Old October 9th, 2008, 11:48 PM   #10
2004 mustang gt
so what hat range is stock in our stangs?
2004 mustang gt-
Old October 10th, 2008, 12:19 AM   #11
BLK2KGT's Avatar
1/8 7.95@82.43
You also might want to keep an eye on your fuel pressure, a buddy of mine moved from a 75 to a 125/100, can't remember which, and his rail pressure dropped down to like 23 psi or somthin. Im runnin a 100 w/ no tune and no programmer at all so thats next on my list. But btw the zex kit is simple to install. If you have a whole day deddicated to it, it shouldn't take more than a day. But planning is key like 04mustang232 said, map out where and how you want to run everything, and double check to make sure you have all of the tools nessecary and you should be set.
If you're not 1st you're last
-Ricky Bobby
Topless Mustang Club Founder
Old October 10th, 2008, 12:30 AM   #12
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
its a strait foward install. i junked the NOS solenoids in favor for a zex box.
stock long block, bolt ons, slicks, and a little squeeze
N/A-12.81@103.7
N2O-11.79@115.8
parting out 04 cobra, pm me for details
Old October 10th, 2008, 05:39 AM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
as for ngk's they are a 5 so Tr55's for vpower or ITR5F13's for laser iridium. so if you wan't a colder ngk you will need the TR6's
Threads Similar to: new zex kit
Zex Dry Kit 1979rs/z28 99-04 20 July 28th, 2008 09:40 AM
Zex Kit 2 Days Bhblondguy 2005+ 9 July 7th, 2008 03:55 PM
Zex Nitrous Kit acmillr Power Adders 9 February 22nd, 2008 04:43 PM
Ok, so I got this new ZEX kit. STANGATUDE 99-04 4 October 17th, 2007 02:17 PM
zex kit set up militarygt Poweradders 3 July 18th, 2006 11:25 PM
