!FACEPLATED!
Battery Relocation
For those of you with a New Edge with the battery mounted in the trunk, where did you run your kill switch too? Im thinking about getting a push/pull kill switch and having the rod go through the passenger side reverse light.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
kill switch for what?
Vortech V2 Si
2001 Mustang GT
13.15@101
To kill the Battery if the car is wrecked or catches on fire...
So it will shut off the fuel so it wont make it any worse... |
1997 Mustang GT
Faster than an s4
Its a requirement of certain tracks and of the racing association at a certain speed car. Its not necessary I don't think untill you like into the 10's. It has to be easily accessable. So someone other than you can pull it while you are still in the car. Most people put them in the middle of the back or on the fender. I don't think its really all that important, I'd read the rule book to make sure though.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Moderator
2010 mustang gt auto
look into streetleathal.com there a local shop here in pgh pa. Terry makes a very nice set up that goes thru the lock hole & mounts to the under side of the trunk lid. very nice well thought out kit, you'll like it.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
Proud American
Any car running NHRA rules with a battery anwyhere other than stock location, has to have a kill switch that goes on or off or PUSH for off...
Here is how i have seen one, ![]()
!FACEPLATED!
I like that set up matt. I think i might have to do it that way. i know a guy at the track i run did his in the same location but it was just a push button type that worked a solenoid but the solenoid would always get hot so he would hook it up for inspection then disconnect it.
13.86@100.3
MUSTANG-UPR Products.com
i plan on a setup using this that i have seen a friends 9sec fox. he has it mounted behind license plate and used tubes from lows to mount license plate over it. nxt time i go there i taka pic
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
Threads Similar to: Battery Relocation
| Battery Relocation | ThreeHonks302 | 5.0 Mustangs | 4 | February 28th, 2008 08:47 PM |
| Battery relocation | whitemustang02 | Audio/Video | 2 | February 20th, 2008 12:39 AM |
| Battery Relocation | dgt_mustang | V6 Mustangs | 17 | December 21st, 2007 12:00 PM |
| battery relocation | onewinner | 5.0 Mustangs | 13 | May 29th, 2007 04:17 AM |
| Battery Relocation | 98vortech | Modular Mustangs | 0 | September 14th, 2006 07:23 PM |
