About to throw at match at it.
LinkBack (1) Thread Tools
Old October 11th, 2008, 02:49 PM   1 links from elsewhere to this Post. Click to view. #1
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
My car keeps stalling while under heavy acceleration. Plus missing and holding back occasionally under light load.
I had the codes pulled today and this what I got
PO352 Coil B ignition coil B primary/secondary malfunction
PO353 Coil C ignition coil c primary/secondary malfunction
PO354 Coil D ignition coil d primary/secondary malfunction
PO358 Coil H ignition coil h primary/secondary malfunction
I know it's related to the coil packs, but I doubt 4 are going bad all at once. Also what's meant by secondary malfunction?
My car has been such a PIA this year I have almost given up on it please help me.
2000 GT 665/540rwhp/rwtq On pump gas
Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S
DYNO VID --->
http://www.youtube.com/watch?v=K9uOS732mdA
Old October 11th, 2008, 03:45 PM   #2
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
I want to see the video!!!
Old October 11th, 2008, 04:32 PM   #3
neverfastenough1's Avatar
Considering there are 3 codes on one bank and one on the other, I would say either you have 4 bad coils, bad computer, or a short in the wiring harness somewhere. Don't quote me, but I think the secondary circuit is before the coilpack and the primary circuit is from the coilpack to the plug. Good luck getting her fixed.
Old October 11th, 2008, 04:32 PM   #4
TyCouey2000GT is an unknown quantity at this point
Either way whatever it is you aught to get new cop,s
I read on google from a person with an expedtion threw the same same, they changed cops and it ran better but still threw code, so they changed plugs and it turned out #7 wasnt making contact with the plug so after new plugs it ran perfect
Your Average GT
Old October 11th, 2008, 09:04 PM   #5
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
hope you figure it out before it pisses you off to the point of no return... happend to me, i sold the car without looking back and now wish i had it back
Old October 11th, 2008, 09:15 PM   #6
MyGT's Avatar
13.1@105
MyGT has a spectacular aura aboutMyGT has a spectacular aura about
iTrader: 6 reviews
Still running stock cops? Idk if this might be the opportunity to upgrade.
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees!
Old October 11th, 2008, 09:19 PM   #7
Proud American
MustangMatt96GT's Avatar
Jive, i know how you feel... If i take a break from the car, about a week, the energy to get it fixed comes back.
But i would be looking into new Cops and if that doenst help then probably a ECU going bad from all those times its been and out with that chip
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old October 12th, 2008, 02:57 AM   #8
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
Sorry to only post part of your quote, but that is really what im thinking. Sounds like that PCM is getting extremely flakey. Especially after all the other problems with it you have had.
Old October 12th, 2008, 03:00 AM   #9
dude496's Avatar
04 Mustang GT
or another thing could be you have a seriously jacked up wiring harness. I really gotta find my ford cd and find if all of those are on the same bank
wanted to add this...
Do you have a multi-meter? Specifically an Ohms meter (omega symbol, looks like a horseshoe)? If you do, I can look at the pin out and tell you where to check on the wiring harness.
Old October 12th, 2008, 10:36 AM   #10
jivepepper's Avatar
Yeah I have a multi meter.
Well I had one cop off a different motor on coil #8/H. I replaced it and so far it seems fine. I think it might have missed a little once on the way back home but no dying during acceleration. Could a coil pac shorting out cause the others to throw a code?
I also put in 2 Aviator fuel pumps in my cobra set up yesterday, and I'm throwing a P0190 which is a fuel rail pressure sensor malfunction at start up.
Pretty sure it's because of a fuel pressure spike at start up.
I earlier removed the PPRV (postive pressure relief valve), pulse dampner (silver disc near yje fuel rail), and added a bigger line from the fire wall to the fuel rail utilizing a Russel -An to ford EFI fitting. There's a huge difference between the stock fittind and the Russel. If you try to blow through the pprv or the pulse dampner it almost impossible.
Lot of restriction
Stock fuel rail fitting VS Russel fitting
PPRV
DYNO VID --->
Old October 12th, 2008, 11:54 AM   #11
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
Originally Posted by neverfastenough1 View Post
<snip>Don't quote me, but I think the secondary circuit is before the coilpack and the primary circuit is from the coilpack to the plug.<snip>.
Sorry 'bout the quote thing...
The primary of any transformer is where the power goes in, the secondary is where it goes out. So for our COPs the primary is the low voltage side ("before" the COP) and the secondary is the HV side, "after" the COP.
To the OP,
Here's is what the '03 shop manual says about P0351 through P0360.
I would check out the wiring before buying any COPs.
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Old October 12th, 2008, 06:53 PM   #12
jivepepper's Avatar
It isn't dying anymore. But it still holding back once in a while at part throttle and little load. It sounds kind of fluttery ( can't think of a better world) if I punch it all at once it pops and goes away?
DYNO VID --->
Old October 12th, 2008, 11:11 PM   #13
13.00 @ 105
its sounding more and more like a fuel issue somewhere... most likely tune related. Have you datalogged it?
Old October 12th, 2008, 11:37 PM   #14
texasd18e's Avatar
2001 Mustang GT 5.8
texasd18e is on a distinguished road
actually it sounds kind of like a bad EGR valve. usually if it sounds like a fuel problem but theres no problem with the fuel parts then its an EGR problem.
351W
c4 tranny
AJE suspension
slowly building
Old October 13th, 2008, 01:27 AM   #15
jivepepper's Avatar
I got this reply from another site.
Originally Posted by Mustangxtreme27
The same thing happened to me a while back. I had the codes pulled and I got the same thing as you (well only 2, not 4);
PO352 Coil C ignition coil C primary/secondary malfunction
PO353 Coil D ignition coil D primary/secondary malfunction
Guess what it was? The fricking MAF, just like candyandchrome mentioned. By the way, I had the stock ignition like you. Good luck with that, hope you get it taken cared of soon.
Well I removed the extended wire that I added to the maf harness when It use to be in the fender and all seems good so far. I took it to interstate and went to redline in 2nd, 3rd and 4th about 3 times, There was no dying, holding back, and no melted electros like it did at the track. But I'm sure the last one was also helped when I replaced the Cobra pumps with Aviators
DYNO VID --->
Old October 13th, 2008, 01:38 AM   #16
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
glad to hear things are starting to look better for ya.
Old October 13th, 2008, 02:50 AM   #17
dude496's Avatar
04 Mustang GT
did you use a pigtail or did you solder in more wiring to extend the MAF cable?
Old October 13th, 2008, 05:06 PM   #18
jivepepper's Avatar
Both a new pig tail and extra wire.
Well I spoke to soon. Went out today and it started holding back again at light load and low rpm, I wish I could find some one to borrow a SCT 2400 maf off of to see if it's the problem.
DYNO VID --->
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/92568-about-throw-match.html
About to throw at match at it. This thread Refback October 11th, 2008 04:02 PM
Threads Similar to: About to throw at match at it.
Color Match and Wheels bostonbands 2005 - 2010 10 February 7th, 2008 11:22 AM
Any Gasket Match ??? sn94 5.0 Mustangs 1 January 10th, 2008 07:01 PM
will an 02 gt motor match up to 99 components? a_calm_victim 99-04 7 July 11th, 2007 06:59 PM
Cannot Match Paint On New Bumper! Any Ideas? Invictus Modular Mustangs 13 March 18th, 2007 03:31 AM
