Discussing parking brake lever in the 99-04 Forum. How can i increase tension on line? it takes to far up to engage brakes. ...
Old October 12th, 2008, 12:52 AM   #1
adrenaline=lifeline's Avatar
13.86@100.3
parking brake lever
How can i increase tension on line? it takes to far up to engage brakes. theyre new too
13.96 at 97.49
STOCK AUTO
13.84 at 100.3 (spinning)
W/3.73s
Next Mod: Motor/Tranny swap
Old October 12th, 2008, 01:12 AM   #2
99mustanggtman's Avatar
1999 GT
Go up under the car and adjust the cable.
Vortech V2 SQ @ 11LBS
-Ray
Wrong: Their is no one here.
Wrong: Shelley wants to know if there busy.
Wrong: The dogs are happily chewing on they're bones.
RIGHT: I can't believe they're leaving their children there alone!
Old October 12th, 2008, 11:20 AM   #3
RavensChild's Avatar
1998 Mustang Coupe
Amazing
mine barely works. I have to engage it all the way just to hold the car still. About 3/4 the way and i almost roll. I was a dumbass and drove about 1mile or so with it on when i first got it.
Car Tuned By Joe At TrickTuners.
Originally Posted by 96GTRagTop View Post
u have no idea the amount of porn i go through in one day
Originally Posted by TurboLX View Post
how the hell did you get the arrow to point down?
Originally Posted by GenevieveD View Post
its the letter V ..silly
I have made Zip ROFLMFAO, have you?
Old October 12th, 2008, 11:33 AM   #4
13.86@100.3
dont feel bad.....i did a burn out..... but theyve been replaced since then so how do i tighten it?
13.96 at 97.49
STOCK AUTO
W/3.73s
Old October 12th, 2008, 12:56 PM   #5
13.86@100.3
bump for some help
13.96 at 97.49
STOCK AUTO
W/3.73s
Old October 12th, 2008, 01:12 PM   #6
Stone Cold Mod
TheUNZippee!'s Avatar
2007 Mustang GT
282 rwhp/292 rwtq
Location: I've got Rags in my bubble and I don't know what to do with it!
Found this out there on the interwebs:
ok, hold on to yourself cause this gets messy.crawl under the car and find where the e brake cable attaches it's going to be hard to see the driveshafts in the way.there's a bracket spot welded to the body that holds the rear cables at the attachment point if that bracket is bent down kind of pulled away from the body THAT'S THE PROBLEM the bracket has created slack in the cable it's got to be pushed back up. I jacked it back up and welded it.Not for everyone and not so easy either.
If the bracket is not the problem then you have to go in the console at the top of the brake handle there's a chrome clip thats attached with a 8mm bolt on the right side of the handle. When removed it releases the gears of the handle so you can adjust the cable. that's the adjustment point.This is where if you can get this to a dealer-machanic-buddy that has done this before it will save you alot of work, I know I did it the hard way.Not that you can't do it but it gets messy.
By the way once the cable is tight and the handle only clicks about 3times when you pull it and for some reason you want to remove the console,the console want come out cause the handle has to be almost straight up for the console to clear,remember the little chrome clip cause that's the only place you can release the handle.lots of luck hope this will help
Dyno Pull/MBRP's - The pee Test
My Mods
Originally Posted by OMU
don't look like a loser when posing.
Threads Similar to: parking brake lever
parking brake 1BADSTANG 5.0 Mustangs 3 April 23rd, 2008 01:44 AM
Parking Brake billb303 5.0 Mustangs 2 April 12th, 2007 06:43 PM
Parking brake boot Endzone108 Visual 1 April 10th, 2007 02:05 AM
Parking Brake Light ON! edmdi Electronics 13 February 21st, 2007 11:29 AM
parking brake wildfaststang 5.0 Mustangs 3 February 1st, 2007 02:58 PM
