2001 Mustang COBRA
13.39@106.36
vibration from tranny at high speeds?
I noticed at about 90 plus mph i feel a strong vibration coming from the trans. I checked my wheels balanced my driveshaft and cant find anything wrong. does anyone els have this problem please tell me how to fix it.
My friend has a the same problem with his GT. we both have alot of hard mielage on our cars. is there a bearing or something that can go bad in the tranny that becomes a common problem plz help. |
im sure it aint your tranny, its either your driveshaft or tires not balanced.. could be from locking lug nuts too... but probably your driveahaft. weve all had this problem
Your Average GT |
2001 Mustang COBRA
13.39@106.36
i doubt it's my driveshaft i have rebalanced it already?
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
check u joints and trans mout.
2001 Mustang COBRA
13.39@106.36
i replaced u joints. so ill check trans mount.
TT Bullitt
![]() iTrader: 2 reviews
Have you changed the gears in the rear end?
2001 Mustang COBRA
13.39@106.36
no i have not.
Admanistrator
a lightweight aluminum ds would probably help, but when you say 'checked your wheels,' does that include the air pressure and balancing?
2001 Mustang COBRA
13.39@106.36
Yes
Driveshaft problem I think.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
![]() iTrader: 3 reviews
could be a loose pinion, tranny mounts, unbalanced drive shaft. Also if you tuned you vehicle and you advanced your spark plug timing all the way it may cause your engine to vibrate under accel. but you say it only occurs at 90 mph so you might be able to disregard that. Also tire balancing and air pressure. That's all I can think of right now
2001 Mustang GT 5.8
might be your reverse lights. when it starts vibrating have someone ride behind you to see if the reverse lights come on when you throw it in reverse. if they come on then it's your driveshaft. if they don't come on then it's your tranny mount. hope this helps.
![]() 351W c4 tranny AJE suspension slowly building |
#13 | |
so your telling him to put his shit in reverse at 90mph?
2003 mustang gt/ 87 lx
11.92@114mph
check your rear upper and lower control arm bushings if they are worn out it will make the rear vibrate at certain speeds i just found that out with my car.
2001 Mustang COBRA
13.39@106.36
thnx for the help im in the process of getting new trans mount. i think its loose. Ive balanced driveshaft replaced all rear bushings in my IRS balanced tires. im determined to stop the slop. thnx for the input guys.
1/8 7.95@82.43
Check you driveshaft bolts I had some come a loose on me after my tranny swap and a couple of weeks later I noticed a good vibration at higher speeds. So I tightend them back up again and it did it again so then I lock tightend them and they have came loose yet
Threads Similar to: vibration from tranny at high speeds?
| Anyone know speeds in each gear for | fasterfrank | 99-04 | 9 | August 20th, 2008 06:11 AM |
| slight vibration at high speed? | 91cobra5.0 | 5.0 Mustangs | 3 | June 22nd, 2008 08:38 PM |
| ???? on 4 speeds | tag team | 5.0 Mustangs | 12 | October 15th, 2007 09:39 AM |
| vibration at high speed help help !!!! | jagstang96 | 96-98 | 6 | February 7th, 2007 08:41 PM |
| auto Tranny vibration-shifting issue | travster07 | V6 Mustangs | 2 | November 7th, 2006 12:21 AM |
