1989 LX
12.60 at 109mph
Stock heads?
so i found some stock heads for my 4.6 modular on craigslist for 275. i called this machine shop in AZ and he said he can port and polished these heads to flow better then the partiot stage 3 heads he didn't wanna give me a price so i don't know if i could believe it or not?
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears soon to come 30lb injectors, Blow through MAF, intercooler and tune |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
is he reputable? will he have flow #'s to prove it?
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
Whats the name of the shop?
1989 LX
12.60 at 109mph
me and 93hatch are gonna go down there wed and look at some heads he already has ported for another customer and has the flow charts for them im gonna see if there worth it. but he said he is gonna port and polish the heads put brass valve guides and brass valve seats upgraded valve springs and hardened valves and he also said something about opening the spark plug threads and angling them and re-threading them he said it's healthy and gives combustion in the cylinder or some BS like that
1989 LX
12.60 at 109mph
sean on this forum had all of his head work and had his 347 stoker done there as well so hopefully there good with the modular motors aswell but idk the name of the place all i got is a number sean gave me?
#6 | |
03 GT
![]() Just some Bolt-ons |
02 mineral grey GT
Ya I'm curious to. If this guy is the real deal it would a good thing to know. Just another option for the rest of us.
Just make sure he puts them on a flow bench to test.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
07 gt
ive been thinking about getting my stock heads done when i get my cams installed. have to check prices
07 GT 5spd Black on Black BBK Equal Length Shorties 4.10s FRPP K springs JLT with canned tune Pypes O/R H Pype Bomb axleback Steeda UDP |
You could have them ported to flow better than stage 3 heads.... but why?
You'll lose low and mid-range. I'd imagine heads that flow that much would be more race-oriented capable of 6500+ rpm. The stock intake would limit it as well as most streetable cams. You sure you want to go that route? I mean if he's porting the heads and he's good at it then cool, but i hope you're saying he's capable of porting them to flow better than stage 3 heads and not that he's GOING to port them to flow better than stage 3 heads... That's overkill imo..
"peak hp doesn't mean ish... Its about the area under the curve mannn..."
07 gt
i didnt know you lost low and mid range power with p&p heads? if thats the case im not doing them
You do and you don't. Depends on what level you get. A set of stage II heads are normally good streetable heads. Stage III you lose low and mid-range but you gain a lot on the upper end, that's more for straight racing than anything. A quality set of stage II heads will make good hp throughout, but your gains aren't going to be incredibly dramatic
Threads Similar to: Stock heads?
| stock heads | Black Five 0h | 5.0 Mustangs | 4 | January 28th, 2008 11:08 AM |
