Discussing heads and cams in the 99-04 Forum. so here goes i have done my fair share of research on heads and cams. ...
Old October 13th, 2008, 11:32 PM   #1
Danderson's Avatar
2003 white GT 5sp
13.66@101 boost times comming soon!
heads and cams
so here goes i have done my fair share of research on heads and cams. I wana have a dd with some power looking to stay n/a (unless i win lots if money). I have seen that one can gain anywhere from 30 to 45 whp with heads and cams. one of my good friends tells me that a lt1 full boltons and hci could reach 400whp. so y do mustangs gain what seems to be so little with hci? What is the best combo for a n/a?
2003 GT 5sp White
Full Bolt On's...with some boost
Full slp exhaust, 4:10 gears, Nitto 315 DR
Vortech V3 non intercooled 9lb boost
350hp 360tq
Old October 13th, 2008, 11:34 PM   #2
Danderson's Avatar
2003 white GT 5sp
i have 4:10 gears that will be installed soon. not sure if that will affect anything
2003 GT 5sp White
350hp 360tq
Old October 13th, 2008, 11:46 PM   #3
2000 Mustang Gt
13.56 @ 106
they dont make as much power as the lt's because of compression, engine size and flow.
my sig has my mods and numbers. you can almost get a full s/c kit for the price of heads/cams/install/tuning
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
Old October 13th, 2008, 11:51 PM   #4
ajm
ajm's Avatar
Id say best combo depends on how much you want to spend, what you want to do in the future, and weather youre looking for low end/top end power, etc, and ultimately buying what you feel is best for you not what everyone else says to get.
Old October 13th, 2008, 11:52 PM   #5
Danderson's Avatar
2003 white GT 5sp
i just saw your post and that is what im looking for 300iish. how much did u spend? i plan on spending 2k doing the install my self and XXX for tuning
2003 GT 5sp White
350hp 360tq
Old October 13th, 2008, 11:55 PM   #6
jivepepper's Avatar
Plus with lt1's and other small block chevys you can buy after market heads. All we can do is port and polish the stockers.
** 2000 GT 665/540 SUPERCHARGED SOHC 2V 4.6l **
**Best 1/4 11.1 best trap 133 80*, 2286' DA 315/35/17 DR'S,**
DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA
Old October 13th, 2008, 11:55 PM   #7
Danderson's Avatar
2003 white GT 5sp
ajm that is y i tryed to explain what my goals would be. i dont want some one to tell me to get xxx bc. i want to know what combos work well.
2003 GT 5sp White
350hp 360tq
Old October 13th, 2008, 11:55 PM   #8
ajm
ajm's Avatar
Dont forget to add in cost of tools (if you dont have them already), head gaskets, head bolts, intake manifold gaskets, crank & cam bolts and any other gaskets you may want to change. While youre at it for the little extra cost you might as well do the front cover and valve cover gaskets. Just something id throw out there so you can figure how much you have/want to spend on actual parts. As for you goals maybe I read over them.
Old October 13th, 2008, 11:56 PM   #9
Danderson's Avatar
2003 white GT 5sp
jivepepper that what he was saying that they get all new heads and i was prety sure that mustang companies just pp ford heads
2003 GT 5sp White
350hp 360tq
Old October 13th, 2008, 11:58 PM   #10
jivepepper's Avatar
Originally Posted by Danderson View Post
ji was prety sure that mustang companies just pp ford heads
Yep that's all there is. No afr's or edlebrock heads for us.
Old October 13th, 2008, 11:59 PM   #11
mystang0673's Avatar
12.0@113
heads and cams are the most expensive least productive mod we have... but that makes a world of difference in the long run... i wanna do heads and cams so bad but im just gonna wait till i build motor...
Old October 14th, 2008, 12:01 AM   #12
Danderson's Avatar
2003 white GT 5sp
i wasnt very specific about goals
300ish whp
total cost around 2500 heads cams gaskets tune
dd
mid to high power band i think
2003 GT 5sp White
350hp 360tq
Old October 14th, 2008, 12:02 AM   #13
jivepepper's Avatar
The truf!
Old October 14th, 2008, 12:04 AM   #14
Danderson's Avatar
2003 white GT 5sp
ok so lets twist this thread a little what would u suguest to do for 2500?
lt headers 699
xpype 350
tb plenum 400
AD 260
i have gears to be installed
2003 GT 5sp White
350hp 360tq
Old October 14th, 2008, 12:05 AM   #15
ajm
ajm's Avatar
Just my opinion..For a start id look at some hitech or crower cams, heads youre best bet as far as saving money would probably be having your current ones p&p, and for a tune a sct x3 with custom tune from somewhere like vmptuning,bamachips,etc. Once I got a price from there id see where I could squeeze in the remaining money for better parts.
Old October 14th, 2008, 12:07 AM   #16
12.0@113
2500 will get you a sc kit and a tune... if you only care to make as much as your internals are good for that would be the best thing... as for me... im doin all the small stuff first then gonna do the big whammy and go from runnin mid high 11s to mid high 9s... so.... there ya go... you can get an s-trim kit for about 1800 off of corral.net and a dyno tune for 700
Old October 14th, 2008, 12:07 AM   #17
ajm
ajm's Avatar
lt headers 699
xpype 350
tb plenum 400
AD 260
Have you thought of trying to save some money and do the gears yourself? If youre willing to do the cams and heads you should be more than capable of doing the gears. They arent that complicated to do it just takes a little time, patience & abillity to read a dial indicator & dial caliper.
Old October 14th, 2008, 12:12 AM   #18
jivepepper's Avatar
And a lot easier to install with a lot more potentail. not to mention the cool factor.
You better do a real big whammy like a novi 2000 or YSI-trim if you want nines, then you'll need an 8 rib set, over drive crank pulley ect. The pulleys alone can cost almost 900. Don't forget the race gas at $6 a gallon. There's a huge difference going from high 13's to 11's compared to going from 11's to 9's
Old October 14th, 2008, 12:18 AM   #19
Danderson's Avatar
2003 white GT 5sp
i did think about it have all the tools i need just dont know how to do it right.
2003 GT 5sp White
350hp 360tq
Old October 14th, 2008, 12:19 AM   #20
All Throttle with a Bottle
MustangMatt96GT's Avatar
6 a gallon?? i pay 7.95 for 104
1996 Mustang GT with a 351 swap with Stalled C4
1997 F250 Powerstroke
1999 28' Classic Dominator
Special Thanks to: Andrews Racing Transmissions
& Thanks for the help: PoorManMotorSports
"Just Cause its Smoking, don't mean its broken"
Threads Similar to: heads and cams
PI heads and cams mystang0673 Engine 2 February 8th, 2008 12:09 AM
Heads and cams mystang0673 99-04 1 September 2nd, 2007 03:43 PM
heads/ cams bluemustang04 Modular Mustangs 5 July 6th, 2007 04:18 PM
Heads and Cams help please! 00silvergt 99-04 4 June 10th, 2006 09:56 PM
heads and cams? Drgnracin72 99-04 4 June 9th, 2006 01:04 PM
