U joints goin bad? - Forums at Modded Mustangs
post #1 of 16 Old October 14th, 2008, 12:08 PM Thread Starter
I Poop Entirely Way Too Much
U joints goin bad?
So I got the s/c about a month ago and now when I let off the gas during normal driving just to and from work I get a bucking motion. There no unusal engine noises but there is some noise from the tranny due to the bucking. Its not too serve but definately noticeable and usually only last for a second or so. I think I remember this being symptom of bad u joints but Im not sure. If it is how can I confirm it.
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #2 of 16 Old October 14th, 2008, 12:22 PM
MM.s Used Car Whore
svtkidd23's Avatar
i got the same problem!!
goin up a hill! in 5th goin 40 you;ll feel it to
I hate bronys
svtkidd23 is offline
post #3 of 16 Old October 14th, 2008, 12:28 PM Thread Starter
Yeah i notice it in 5th, or any gear at lower rpm. It seems to occur when ever the torque applied is at the low end.
post #4 of 16 Old October 14th, 2008, 12:32 PM
FoxHoss's Avatar
Send a message via AIM to FoxHoss
are you sure thats not the normal transmission noise? they normally make some clunks and clicks when getting on and off the gas because of the necessary clearances in the transmission
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
FoxHoss is offline
post #5 of 16 Old October 14th, 2008, 12:42 PM Thread Starter
the clunks and clicks come with the bucking. Its seem a lil much for gettin off the gas.
post #6 of 16 Old October 14th, 2008, 01:17 PM
i had the problem, so i said fuck it and changed to poly mounts on the tranny and motor, stopped the bucking, but you still can hear the clutch beat around inside the tranny. kinda scary
and why would you go uphill in 5th doin 40?
04 Redfire Cobra SVT - JLT RAI, Bassani Catted X,Borla Stingers, MGW STS, Tune
08 Mazdaspeed 3 - Too many boltons - SOLD
00 Mustang GT - Too many boltons - Traded
RC04SVT is offline
post #7 of 16 Old October 14th, 2008, 01:26 PM Thread Starter
Ive never gone up hill in 5th at 40, but at lower rpm i notice th problem alot.
RC with the poly mounts do you get any more vibrations in the car?
post #8 of 16 Old October 14th, 2008, 01:31 PM
amateur adult film star
sgrcltpunk's Avatar
Send a message via AIM to sgrcltpunk
coil
performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
sgrcltpunk is offline
post #9 of 16 Old October 14th, 2008, 01:59 PM
its not how people make it out to be, when you accelerate you dont feel it, at idle its minimal, and the tranny mount cleared up my shifting problem. when i ran the car before, when i hit the clutch the dmn tranny would smack around left and right. fuckin ridicoulous, i had enough with it and fixed it. dont regret it. The motor mounts was choice for me, just one less thing down the road. Id recommend them, more for tranny then anything.
RC04SVT is offline
post #10 of 16 Old October 14th, 2008, 04:31 PM
MM.s Used Car Whore
svtkidd23's Avatar
hahaha i said low rpms.. just thats when u no it the most. like little ass hills in my neigborhood. in 5th
I hate bronys
post #11 of 16 Old October 14th, 2008, 04:36 PM Thread Starter
Still havent gotten a answer to the question, how can I check if my U joints are goin?
post #12 of 16 Old October 14th, 2008, 04:39 PM
MM.s Used Car Whore
svtkidd23's Avatar
jack ur car..
grab driveshaft shake it back and forth.. or rather twisting them..
and if it has alot of play there ya go! u joints bad
I hate bronys
post #13 of 16 Old October 14th, 2008, 07:25 PM
u-joints arnt that expensive compared to alot of things, if you think thats what it is then change them. maybe try and grease it and see if it helps. if there is ANY play in the u-joint change it. there should be none at all
RC04SVT is offline
post #14 of 16 Old October 14th, 2008, 08:37 PM
Mustang tansmitions build up slack after hard driving and especially launching. The only way to tighten up the slack for good is getting a new tranny. if not plz let me knoe another way to fix this problem.
VinceSVT is offline
post #15 of 16 Old October 14th, 2008, 09:06 PM Thread Starter
SVT...thanx I gotta send my blower to get rebuilt it makin some bad noises so well thats away Ill get under and check it out.
RC...If theres any play at all Im ordering a aluminum driveshaft, They arent too expensive either.
Vince...Im hopin its not the trany, theres not noise from normal driving just when the speed between the wheels and engine varies while its in gear. The car only has 40K on it and I dont beat on it. Hopefully its not the tranny cuz if it is it wont last long with the blower.
post #16 of 16 Old October 14th, 2008, 10:38 PM
neverfastenough1's Avatar
Just switch to a lower gear. Sounds like a worn or out of adjustment clutch trying to power thru too high of a gear at too low of a speed under load.
neverfastenough1 is offline
Human Verification
