turning traction off
other than buying a tuner,how can i turn my traction control off,my button doesnt work an i want it off for good but i wont spend money on a tuner just to get it off,any ideals
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
dealership?
i think there is something that turns it off ive seen it before on like ebay
Moderator
2010 mustang gt auto
take the fuse out.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
Unplug it in the trunk.
i heard that taking the fuse out wouldnt cut it off,an how do u turn it off from the trunk
KB'd GT
you could probably by a momentary switch at radio shack for a few bucks and rewire it.
The OEM switch is a momentary switch, here's the wiring diagram:
![]() It is the pushbutton switch in the center left. Pressing it pulls terminal 9 on the instrument cluster electronics high and the cluster then sends a message to the ABS module (that's the unit with the SCP+ and SCP- inputs). SCP is Serial Communications Protocol. When the ABS module gets this message it "toggles" the state of the t/c--if it was ON it turns it OFF, and vice versa. The instrument cluster receives an SCP message and turns the LED on (for t/c OFF) and off (for t/c ON). If not disabled in the tune the default state is ON. There is no way to use another type of switch to make it automatically turn off. I have read of people that just shorted the switch wires and claimed that worked, however I would be concerned about leaving that input to the cluster permanently pulled high when it was not designed to be so. I am also doubtful of claims that says this works, or that it works consistently. I suppose it might if the startup sequence of all the modules is fixed and the cluster comes up after the ABS module. I have also seen somewhere of someone that used an electronic circuit using a dual 555 timer IC firing a transistor to pull the cluster input high momentarily sometime after the ignition was turned on. That's a lot of work to do something that you can do with a tuner that you'll be wanting someday anyway...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
or you could buy a new switch, wont keep it of forever but youll be able to shut it off
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
Threads Similar to: turning traction off
| Turning my '02 GT into a Saleen (Help) | Katiekata | 99-04 | 3 | March 5th, 2008 03:09 PM |
| Having trouble turning over? | ricerraper33 | V6 Mustangs | 14 | November 11th, 2007 01:36 AM |
| Turning up timing | nasty92LX | 5.0 Mustangs | 50 | March 20th, 2007 07:43 AM |
| 95 GT turning off while driving | new 5.0 | 94-95 | 12 | February 19th, 2007 02:05 PM |
| intervention?...I am turning myself in | innrkid | Pictures | 10 | January 27th, 2007 04:17 PM |
