multiple problems
Old December 12th, 2006, 03:34 PM   #1
4.6gtmarine is on a distinguished road
multiple problems
well, really there are two major two major things bothering me. there is a constant howling coming from the rear (there are no aftermarket gears) which only makes noise when car is in gear and clutch is out. second, is there is a squeeking coming from the right front of the car when i pull out in first gear. please help i need to know what to fix....
Old December 13th, 2006, 08:44 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
i would check the fluid level in the rear, if it is low find out where it was leaking (axle seals)? not sure about the squeeking... could be a number of things does it make the noise if the car is off and you bounce the front end?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old December 14th, 2006, 12:11 PM   #3
multiple problems
nope, it only making the noise when i'm pulling out of first. could it be the cats rubbing? or maybe there is some suspension issue?
Threads Similar to: multiple problems
2.3L Problems. akatagyourit 2.3 Mustangs 51 June 25th, 2007 03:39 PM
more problems ks_emt 2.3 Mustangs 7 June 7th, 2007 03:16 PM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 12:58 AM
Multiple Error Codes, Suspect O2 Sensor Zadkiel V6 Mustangs 5 October 31st, 2006 06:46 PM
Help Please (Car Problems) 98mustang98 V6 Mustangs 1 October 25th, 2006 10:49 PM
