changing heads...windsor to romeo
what all would i need to change my 00 4.6 windsor heads over to the romeo head off a 03 4.6 gt....only thing i see differ is the 11 bolts holding the valve cover on..
heads an valve cover is the only thing differ .am i right or wrong and is there any differ in performance of the 2 heads and what is the cost of labor of this job im not really looking for performance head unless i find a good deal on them,
2000 Mustang Gt
13.56 @ 106
should only be new valve covers and oil cap.
there is no performance difference. why would you want to switch stock for stock?
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
cause mine has a blown plug an i can get the other heads which have more thread to hold the plugs in.an they have 25k on them mine has 106k
Proud American
also 6 or 8 bolts on the timing cover go from a M10 to a M12 thats the only difference i see.. other than the valve covers... oh and then chain guide on the drivers side only uses one bolt instead of two like the romeos, no big deal though.
04 Mustang GT
Why spend the extra money on a different set of stock heads? If your going to spend that kind of time, you might as well do a cam and port and polish job.
Just cause you blew a plug doesnt mean its time to upgrade unless you want to....if your on a budget you can do a time-sert and will be just fine. Parts will cost about $35 and does not require pulling the heads. |
i have already fixed the blow out,the heads off the 03 i can get for basically nothing. an i wont have to worry about the blow happening again.i dont want to spend 1000k plus on after market heads.....i DONT have that kind of money to dish out,this will be around feb or march before i do this,im just gettin a good ideal of what its goin to cost so i can save to have it done..even at tax time i wont be able to because im buying a doublewide then.
all im asking is what all is needed an what is the difference an can it be easly done
Ive done the exact same swap for the exact same reasons. its cake....more or less, LOL. If you have any questions, just let me know.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
oh, as for parts you would need - the valve covers, oil cap, and the couple of different sized bolts that hold the timing cover to the head. Thats pretty much it to my recollection. Everything else can be swapped over.
Threads Similar to: changing heads...windsor to romeo
| romeo or windsor | mystang0673 | 99-04 | 31 | November 25th, 2011 10:34 PM |
| Romeo or Windsor Heads | jrfan4life | 99-04 | 10 | November 17th, 2007 06:16 PM |
| romeo heads on windsor block | 2kGT | 99-04 | 16 | November 1st, 2007 06:51 PM |
| Difference between windsor and romeo heads | suds488 | 96-98 | 0 | October 30th, 2007 06:29 PM |
| romeo or windsor | energiesource | 99-04 | 1 | September 29th, 2007 02:59 PM |
