Advantages of Big Bore
Old October 24th, 2008, 06:05 PM   #1
whtpny's Avatar
whtpny is on a distinguished road
Send a message via AIM to whtpny
Alright.. I've been delving deep into the fathoms lately and reading old threads regarding all sorts of topics. Something I've seen in a few is the topic of a big bore "3.700." It is actually something that ACMillr suggested to me a while back. I understand, it is a larger than stock bore that increases the cubic inches to 302 with the stock stroke. My question is what is the advantages or disadvantages of the big bore setup. I've seen some guys saying that high 300rwhp numbers are not out of the question with this setup. I've seen plenty of people praising them as good options, I am just trying to learn the specifics of what makes them better or worse than any of the other options for people looking to build their motor for power and durability. Enlighten me if you guys don't mind.
Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Magnapacks
WhtPny's Videos
Old October 24th, 2008, 11:22 PM   #2
whtpny's Avatar
bump
WhtPny's Videos
Old October 24th, 2008, 11:32 PM   #3
adrenaline=lifeline's Avatar
13.86@100.3
adrenaline=lifeline is on a distinguished road
a disadvantage is thinner cylinder walls
2004 40th Anniversary GT
Pro 5.0 Shifter
Lowered(H&R Springs)
Summit Hpipe w Dynomax weldin mufflers
Minor odds and ends
Old October 24th, 2008, 11:34 PM   #4
whtpny's Avatar
that's why i'm wanting to learn all the ins and outs.. what i've read said that they are just as or even more reliable than some other options
WhtPny's Videos
Old October 24th, 2008, 11:36 PM   #5
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
sleeves?
Cars and mod list in garage
I prefer a girl with a cafina
That's Spanish for vaheena
Which is Italian for clam
Old October 24th, 2008, 11:36 PM   #6
13.86@100.3
n/a yea sure its great but u hook up some juice or some high psi fi and ur asking for hole in the block. my question would be wat if u did the big bore plus a stroker
Pro 5.0 Shifter
Minor odds and ends
Old October 24th, 2008, 11:36 PM   #7
13.86@100.3
sleeves?
good idea i forgot about those
Pro 5.0 Shifter
Minor odds and ends
Old October 24th, 2008, 11:48 PM   #8
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
Advantages of a big bore are endless. First the obvious add cubic inch, you also unshroud the crampped valves. Anyone who tells you the cylinder walls are weak or thin has no clue. A big bore will handle just as much as a stock block, no worries about any power adders at all. The choice of a dry or wet sleeve can make a big difference as well, I prefer wet myself.
Stroking a big bore can get you upwards of 324 C.I., factoring in rod ratio and piston speed it is not my preference to do both but it has been done. If I were going to do another modular bigbore for myself it would be a destroked 5.4. The advantage would be more reliable, stronger, with the ability to spin higher rpms with less stress on the internals.
Old October 24th, 2008, 11:53 PM   #9
Just to add increasing the stroke will generally require a offset piston pin. On a engine that has a long stroke from the get go this will add to the side load on the piston and can cause premature wear. Choosing the correct set up can make all the difference on a combination, be prepared to spend 3000+ on a properly built shortblock (big bore) and figure more for stroker. Piston choice is very, very important as well as a connecting rod that will not grenade.
Old October 24th, 2008, 11:57 PM   #10
whtpny's Avatar
so more cubic inches and more room to breathe is the big kicker that results in the extra power.. wet vs dry sleeves.. someone told me wet sleeves were more prone to leaking oil.. is this true or only if they are not done correctly.. also.. rad ratio and piston speed, i guess these numbers are not very optimal if both stroked and bored? why is it that this doesn't seem to be a popular road for people (doing a big bore)?
WhtPny's Videos
Old October 24th, 2008, 11:59 PM   #11
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
I agree with the destroked 5.4l. When I was seriously looking into the big bore,I was finding out a lot of people having head gasket sealing issues. the big bore option was not that much more money,the sleeves from ford (SVT)was around 50 and my machinist would install for 400 and piston cost was really no more$$. but the head gasket thing stopped me
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old October 25th, 2008, 12:01 AM   #12
Wet sleeve can be a problem , having someone that does them regularly helps there. Big bores are usually more in cost and people choose to go stroked for this reason maily. You can expect 400rwhp with a well thought out build using a big bore, if you have the money do it.
Old October 25th, 2008, 12:02 AM   #13
blackstang2004's Avatar
blackstang2004 is on a distinguished road
you could get the boss block. it has a 3.7 bore
DD-2002 Tacoma 4x4
2004 Mustang GT- sold "will be missed"
Old October 25th, 2008, 12:04 AM   #14
This is probably the easiest route and honestly the smartest.
Old October 25th, 2008, 12:16 AM   #15
whtpny's Avatar
so the boss block is something i should look at? the ~400rwhp is that with mad high compression or something around 10-11 with full bolt ons heads and cams, the whole nine yards?
WhtPny's Videos
Old October 25th, 2008, 12:26 AM   #16
whtpny's Avatar
i've seen the teksid aluminum block as a suggestion, as well.
WhtPny's Videos
Old October 25th, 2008, 12:29 AM   #17
im thinking of doin the boss block an stroking it. my setup would be n/a. maybe a 100 or 125 shot for the track.
DD-2002 Tacoma 4x4
Old October 25th, 2008, 12:32 AM   #18
DiZzyBonne's Avatar
2001 Ford Mustang Bullitt
DiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the rough
Send a message via AIM to DiZzyBonne
Sorry for taking this a bit off topic, but what's the difference between stroke and bore, besides the obvious of stroke being a longer cylinder wall vs bore being a wider cylinder wall? If I'm not mistaken, a longer stroke is generally for more torque, vs a bigger bore being generally for more top end? Either that, or will a bigger bore give you a better overall torque curve? Whatever, just what's the difference between the two lol.
Current mods:
  • Maximum Motorsports XL Full Length Subframe Connectors
  • Catted Bassani X-Pipe
  • Borla Stinger Catbacks
  • H&R Super Sport Springs
MM Bullitt Crew Founder and Member #1
Old October 25th, 2008, 08:53 AM   #19
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Wrong, the walls are siamesed in the Cleveland cast blocks...
sleeves?
The new ones are not sleeved.
WRONG
Right, but I think the 3.7" bore/ stock stroke 302 would be the high revver of choice.
Old October 25th, 2008, 08:54 AM   #20
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I think you could knock on the door of 400 with a big bore set up, 11:1+ compression, big bumpsticks, a great set of heads, and a solid intake.
Threads Similar to: Advantages of Big Bore
4.6 big bore? product1620 96-98 7 August 31st, 2008 01:39 AM
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 06:28 PM
MAF advantages? chadscharged50 5.0 Mustangs 8 March 27th, 2008 12:36 PM
Kenne bell big bore 2.1 00mustanggt 99-04 3 January 18th, 2008 05:09 PM
Tuned for 87 / 91 - Advantages? goodeye 2005 - 2010 4 June 27th, 2007 06:47 PM
