LinkBack (2) | Thread Tools |
#61 |
03 GT
whats your 60 foot?
![]() Just some Bolt-ons |
#62 | |
Pig Romancer
2003 GT
300.32@5.02mph
#63 |
its a 2 flat on street tires, could be better. I was using 245's though, my 295's are way too heavy especially since they're on my 18'' rims. The 245s are on the 17's
and when i used dr's it was too cold. I was getting 2.2 60's. I even burned em for a full 8 seconds and launched at freakin 1200 and they still spun like mad. it was 38* out tho hahah
#64 | |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Ummm, OK. Why don't you let us all in on the facts then.
#65 |
Why?
![]() 03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot May it R.I.P. New whip: 1953 Ford Mainline Coupe... let the games begin! |
#66 |
Aftermarket heads are huge. A set of ported heads, that cost 1600+, adds about 20-30 rwhp, and that number just gets larger when you add F/I. A set of aftermarket heads is going to make the same, or better, numbers and most likely will still have room for more porting and therefore more gains. A good set of aftermarket heads could have guys looking at 350 rwhp n/a without having to go as all out as acmillr did. Not to mention with a new set of PI Heads coming in at 700+ from Ford, for an extra 300 you could bump up HP quite a bit, that sounds damned nice for someone whose heads are shot. And even better, those gains aren't going to be just for guys racing at 4500+ rpms, a quality head will pick up gains in HP and TQ all throughout the RPM range helping even your typical DD.
#67 |
KB'd GT
Not sure, but i'll find out next week at sema and report back.
#68 | |
#69 |
TT Bullitt
Gregg you've been teasing us all week now.
You better not let us down. ![]() Oh BTW, go ahead and put me down for a set. |
#70 | |
#71 |
Proud American
I would love a set Gregg... I have a nice little 2V that could be a test bed for us at MM
![]() I just have no money for a set of heads like that
#72 | |
Pig Romancer
2003 GT
300.32@5.02mph
![]() Last edited by thewayshemoves; October 28th, 2008 at 04:55 PM. |
#73 |
I feel it will be hard to make a aftermarket head that out performs a stock ported 2v head. It will cost a fortune to develop, produce, and buy. 900 hp has been made with ported stock 2v heads.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#74 | |
People are comparing these motors to motors that can be bored and stroked 400+ cubic engines Show me a 2v v8 that can break 900rwhp hp with 5 liters or less with only one power adder and stock ported heads. The reason you only see 30 rwhp from stock ported sohc heads is that they already flow pretty good from the factory for a 2v head. I doubt you'll find a stock short compression 5.0 making 350rwhp NA with stock ported heads and stock intake.
#75 |
I have been running a stock tranny at 400+ hp for years. They main way you spin a bearing is with low oil. Your will not hurt the car unless you run slicks and I still doubt it.
#76 |
07 gt
what about over revving (doesnt matter for me b/c i have my limiter set at 5850) i know if you beat the hell out of your limiter the rod bearings will take a shit
07 GT 5spd Black on Black BBK Equal Length Shorties 4.10s FRPP K springs JLT with canned tune Pypes O/R H Pype Bomb axleback Steeda UDP |
#77 |
03 GT, 92 coupe 2.3T
how the hell do I get tickets for sema. I have been trying to find some for the past 6 years. If anyone has some info on next years tickets let me know. I want to go damn it.
as far as heads go, ill wate a few months and see what some of the magazines say about them. you know MM7FF and 5.0mag will get their hands on them asap. |
#78 | |
![]() 75mm PP TB | C&L Racer Plenum | K&N RAI | Steeda Tri-Ax | FRPP 3.73 Gears | FRPP Aluminum DS | MAC O/R H-Pipe | Magnaflow Magnapacks Sniper Tuned ![]() |
#79 | |
I trust mags about as far as I throw a linebacker.
#80 |
MM's Orangest
2004 Mach 1 Mustang
Hey Greg can you wink if you guys are giving love to more than just the 2V guys?
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/94603-trick-flow-heads.html
| Trick Flow Heads - Page 2 | This thread | Refback | October 27th, 2008 02:42 PM | |
| Trick Flow Heads | This thread | Refback | October 25th, 2008 03:23 PM | |
Threads Similar to: Trick Flow Heads
| Looking to get New Heads - Trick Flow or AFR's? | The Novice | 5.0 Mustangs | 21 | October 24th, 2008 12:04 AM |
| trick flow heads fs again | flattusmaximus78 | 5.0 Mustangs | 6 | March 28th, 2008 07:32 PM |
| whats the cfm for trick flow heads | White Thunder | 5.0 Mustangs | 44 | October 18th, 2007 09:59 PM |
| Tuning Issues 5.0 w/trick flow heads | 1slowhatch | 5.0 Mustangs | 2 | April 23rd, 2007 11:56 AM |
| trick flow high port heads anyone? | ih8chevy | 5.0 Mustangs | 6 | April 10th, 2007 11:11 PM |
