How do I get more Traction? - Page 2
LinkBack (1) Thread Tools
Old October 28th, 2008, 01:50 PM   #21
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
dbl. adj. upper control arms, lower control arms, 50/50 shocks, subframe connectors and tourque box reinforcments, and if you want to go a little further get a set of 90/10 or adjustable struts for up front.
And of course drag launch springs will help but alot of people dont want those because they would drether lower their car.
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Old October 28th, 2008, 01:57 PM   #22
Trick Tuners's Avatar
KB'd GT
Some nice 305 or 315 DRs make a huge difference. My bfg drs (295s) made 1st hook as well as second compared to some crappy 295 dunlops i had on. I have the tq arm, lowers, panhard, and the rest of everything mm sells that i dont have in my living room. Gotta fix the truck dif first, the start the install. I figure around the 1st of the year i should have had enough time to get everything in.
Old October 29th, 2008, 05:05 AM   #23
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
better tires and some control arms
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old October 29th, 2008, 05:14 AM   #24
MM's Resident Ginger
BuRnIn_YoUrS's Avatar
2007 Mustang GT
14.6 for my rookie first run ass
BuRnIn_YoUrS is a jewel in the roughBuRnIn_YoUrS is a jewel in the roughBuRnIn_YoUrS is a jewel in the roughBuRnIn_YoUrS is a jewel in the rough
Send a message via AIM to BuRnIn_YoUrS
Putting a fat girl in the back jk.
Mods:In Garage
Military Crew E-5
Aircraft Fuel Systems Journeyman
Old October 29th, 2008, 05:30 AM   #25
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 13 reviews
Old October 29th, 2008, 05:50 AM   #26
2007 Mustang GT
What? Its legit....right?
Mods:In Garage
Military Crew E-5
Old October 29th, 2008, 06:15 AM   #27
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 13 reviews
yeah itll work haha
Old October 29th, 2008, 06:17 AM   #28
01gtMustang132's Avatar
2001 Mustang GT
13.15@101
01gtMustang132 is on a distinguished road
You might want to strengthen up the TQ boxs on rear of the car...
If you bight to hard with the right amount of power you will damage them...
I'm still running stock suspension,4.10 gears,6000 launch,8.5 inch slicks...
Nothing removed from factory suspension but going to remove the front sway bar soon...
Old October 29th, 2008, 02:09 PM   #29
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
01gt. What do u have done to your car? 13.1 with stock suspension is nice
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Old October 29th, 2008, 02:12 PM   #30
amateur adult film star
sgrcltpunk's Avatar
1999 gt
to infinity and beyond
sgrcltpunk will become famous soon enough
Send a message via AIM to sgrcltpunk
lca's uca panhard better shocks better springs
performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
Old October 29th, 2008, 02:18 PM   #31
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
Ford Mustang Suspension at AmericanMuscle.com - Free Shipping!
MAD Stangs #8
Old October 29th, 2008, 05:03 PM   #32
2001 Mustang GT
13.15@101
Pulleys
K@N cold air tube
70mm TB
polished upper
plenum spacer
Predator high octane tune
4.10's
aluminum drive shaft
31 spline Mosers
ford racing 31 spline limited slip
Pro 5.0 shifter,tri-ax handle
weld in flowmasters
8.5 ET Drags WOT launch(6200rpm)
I think that's about it...
I cut a lot of my time in the first 60'...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/94944-how-do-i-get-more-traction.html
How do I get more Traction? This thread Refback October 28th, 2008 10:20 AM
Threads Similar to: How do I get more Traction?
traction 99blkcobra 4V / SVT 15 September 19th, 2008 11:49 PM
Traction help! cammed281 99-04 6 June 25th, 2007 08:12 AM
traction on take off 07stanggt 2005 - 2010 2 May 9th, 2007 10:05 AM
Traction silver99gt 99-04 12 May 4th, 2007 03:24 AM
Traction....I need some chase 5.0 Mustangs 6 February 24th, 2007 10:38 PM
