LinkBack (1) | Thread Tools |
#1
How do I get more Traction?
So i sc'd my car about a week ago and it's taken me about that long to figure out that i'm goin to need more traction if plan on not getting my ass kicked from a dig and/or a 1st gear roll.
I've got 18x10" bullitts with Nitto 555s on the rear (285/35s) & they're not doin me a lot of good lol. I'm not looking to get the equivalent of an AWD takeoff , but I would like to have at least some grip in first gear.What can/should i do to get there?
2003 Cobra Stock as of now... |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
273 gears!!
Wider rear tires and a stickier tire too (555Rs at least, Mickeys if you wanna get serious).
and/or Suspension.
![]() 03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot May it R.I.P. New whip: 1953 Ford Mainline Coupe... let the games begin! |
suspension is where its at,an better rear tires..but mostly suspension
2000 GT
Get upper and lower control arms. Subframe connectors wouldnt hurt either. And aftermarket rear sway bar or swarr bar. Would make noticeable difference.
But your not going to have traction in first unless you have a slick on at the track. Thats part of the joys of the KB. And learning how to drive it! hehe
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
dont demello the clutch
#7 | |
Priest of the Car Gods
There's two ways to go about this: the cheap way, and the right way. You can guess which one actually works. The right way involves going to a torque-arm rear suspension. You're talking probably $1500 in parts, plus whatever labor you can't do yourself. If you're a competent welder/fabricator, you can pick up
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
6.82@100mph 1.45 60'
so are you saying that the way that guy explains it is crap? i have always wondered about books like that...
Definitely MT ET Street Radials FTMFW!!! And ive got 4:10s out back but i dont know how that would work out with your setup
A couple of pics and mod list in my garage.....http://www.moddedmustangs.com/forums...-member-18904/
#10 | |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
control arms, shocks, and tires are my reccomendations. |
A torque arm, panhard bar, upper control arm, and lower control arm.
Or: A watts link, upper control arm, and lower control arm. I recommend the watts link setup. FAYS2 Suspension Fox Body Watts Link From what I know, with a watts link you have to either get a side-exit exhaust, or dump your exhaust, but with FAYS2 watts link setup, you don't have to. I'm not 100% suspension savvy, so if somebody more knowledgeable than I with suspension can chime in and correct me if and where I'm wrong, please do .
![]() Current mods:
MM Bullitt Crew Founder and Member #1
unplug 4 of your coils?
2000 GT 665/540rwhp/rwtq On pump gas Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA |
04 Mustang GT
ah man now you've gone and told everyone the secret to racing the 4.6
atleast they don't know about the timing change for that mod ![]() On topic...looking at your mod list, you havent done any suspension mods...heck just a better set of springs with shocks and struts will be better than where your at right now....also if ya use the search you'll see all sorts of suspension setups out there. Easy free traction mod is removing front sway bar at the track. |
I would at least go to a 315's since you 10" wide rims.
N/A 4v Guru
2003 Mach 1
definitly suspension. It will be the best bang for the buck to hook up in your situation. also I wouldn't go with the M/T drag radials if you drive it everyday, they hook awesome but suck in the rain.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
1996,mustang
around 5's 0-60
sticky tires, upper and lower control arms, wider tires.
bbk cai 8.8 373 dual exuast ported heads bored 30 over forge crank aggressive cam minor shit also [SIZE="4"][COLOR="Red"]crew member #1 that loves mods and administrators[/COLOR][/SIZE] |
Moderator
Everything mentioned, and weight transfer. Move the battery to the trunk. Put some drag shocks on the front and remove the front stabilizer bar to aid in weight transfer.
1997 Mustang GT
Faster than an s4
For most people, the New Upper and Lower control arms are plenty. You are just bandaging a problem rather than fixing it. But it costs more to fix it, and you can still hook just fine with new Upper and Lower Control arms. I would recommend before anything else though, get Subframe connectors. They add chassis rigidity that promotes, safety, solid body weight transfer for better launching and turning as well as making the car body stay in allignment long term.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/94944-how-do-i-get-more-traction.html
| How do I get more Traction? | This thread | Refback | October 28th, 2008 11:20 AM | |
Threads Similar to: How do I get more Traction?
| traction | 99blkcobra | 4V / SVT | 15 | September 20th, 2008 12:49 AM |
| Traction help! | cammed281 | 99-04 | 6 | June 25th, 2007 09:12 AM |
| traction on take off | 07stanggt | 2005 - 2010 | 2 | May 9th, 2007 11:05 AM |
| Traction | silver99gt | 99-04 | 12 | May 4th, 2007 04:24 AM |
| Traction....I need some | chase | 5.0 Mustangs | 6 | February 24th, 2007 11:38 PM |
