Boost gets you laid
what else is needed for a tubular k member?
do you have to run coilovers? i want to do longtubes and if i'm dropping the k member i know i'm gonna want to put a new one in. so what else do i HAVE to get if i get a k-member?
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
Some K-members will accept Stock A-arms and some tubular A-arms will accept stock springs. Depends on the brand
I run a upr kit with tubular A-arms and coilovers
2000 GT 665/540rwhp/rwtq Best 1/4: AT 431HP 12.29 @ 124 AT 515HP 11.24 @ 129 AT 638HP 11.01 @ 135 AT 665HP ??.?? @ ??? 80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S Trap speed = true measurement of HP.
QA1 can accept stock A-Arms.
UPR will need either the rest of the kit OR, you can snag a-arms and a spring perch from a 5.0 (there's one other part too, I forget which one off the top of my head)... but will bring your wheels almost an inch inwards.
![]() 03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot May it R.I.P. New whip: 1953 Ford Mainline Coupe... let the games begin! |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
coild over's arent a have to. i am running a qa1, cobra a-arms, frpp c-springs, and tokico hp struts right now.
I putting together a little coil over set up myself. The QA1 I can confirm comes with the spring perches for stock spring placement. I also have so far, QA1 tubular a-arms. What I need to get to complete my kit are Bilstein struts, UPR coil over conversion kit, QA1 500lb linear rate springs for the front, bumpsteer kit and Caster camber plates.
For the rear, I'm planning on either Eibach or H&R springs with Bilstein shocks. I have CHE Upper and lower control arms pending installation(thanks Faon) Hope that helps.
![]() 75mm PP TB | C&L Racer Plenum | K&N RAI | Steeda Tri-Ax | FRPP 3.73 Gears | FRPP Aluminum DS | MAC O/R H-Pipe | Magnaflow Magnapacks Sniper Tuned ![]() Last edited by DSG04GT; October 29th, 2008 at 07:37 PM. |
run a upr kit, comes with everything you need
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
That's the simple way
for $699. I pieced together my own for $560 Either way, you can't go wrong!
![]() 75mm PP TB | C&L Racer Plenum | K&N RAI | Steeda Tri-Ax | FRPP 3.73 Gears | FRPP Aluminum DS | MAC O/R H-Pipe | Magnaflow Magnapacks Sniper Tuned ![]() |
Damn UPR just raised the price to $750
Maybe so, but the upr kit is still listed as 699 at latemodelrestoration.
Ebay that sucker. There should be new kits selling for a little less
That is a new kit, but your right I am sure you can find some kits for less that are factory defects or cheaper manufacturers on ebay.
Boost gets you laid
ebay has the qa1 kit for 469 is that a decent one?
If I were going with a QA1, I would get this one and use the stock a-arms.
Otherwise, I would definately pay a little more for this one if I was getting a kit. It just looks stronger to me. 96-04 K-MEMBER AND COIL-OVER KIT, 4.6L, WITH 12" 200lb COIL OVER SPRINGS MUSTANG
Fixed
![]() 75mm PP TB | C&L Racer Plenum | K&N RAI | Steeda Tri-Ax | FRPP 3.73 Gears | FRPP Aluminum DS | MAC O/R H-Pipe | Magnaflow Magnapacks Sniper Tuned ![]() Last edited by DSG04GT; October 29th, 2008 at 10:11 PM. |
i have an aje k-member with spring perches.. didnt want to do coilovers the ride isnt good to me and they make to muc noise.. so i have tokico 5 ways and just lowering springs..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
#18 | |
Rebel Of The Sacred Heart
'02 GT
Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed.
Wait, are you saying the perches are way too noisy or the coilovers?
Crap, everyone who has them gives QA1 bad reviews on quality and fitment.
Threads Similar to: what else is needed for a tubular k member?
| tubular k-member concerns | foggyracing | 5.0 Mustangs | 5 | August 3rd, 2008 05:31 PM |
| GMS Mustang Tubular K member Kit w/ A-arms, K member, & | 94GTD1SC | Drag | 1 | November 16th, 2007 01:11 AM |
| Tubular K-member kit | acmillr | 99-04 | 28 | August 21st, 2007 02:06 PM |
| Is a Tubular k member a must? | caintcatchmyGT | General Tech | 9 | August 3rd, 2007 12:29 PM |
| Tubular K Member Install | droppedbass87 | General Tech | 27 | October 15th, 2006 05:31 PM |
