12.73@111.36
Odometer Problem Solved -- Thanks for the Help
I took the instrument cluster apart and fixed the odometer problem yesterday thanks to all of the tips I received on the forums. Thanks for the help.
Background: First tuner said I had 3.73 gears. He set the computer to 3.73s. My odometer went off by 17%. ??? The second tuner said I had 3.55s now my odometer was only off 8.5%. ??? Speedometer right, odometer off... WTF? I jacked the car up and checked. I could swear I had 3.27s. I asked about odometer problems but no one had heard of that before. Then I got a tip about the dealer troubleshoot trick with the odometer. You can make the odometer read your speed. I did that and the needle on the speedometer was off 7 mph. The previous owner put in an instrument cluster overlay. He thought zero on the speedometer actually meant zero! The fix: I took the instrument cluster apart. I took the speedometer needle off with spoons according to your tips. I jacked up the car on jack stands and I ran it at 15 mph putting the needle back on at the correct place. The speed according to the odometer and the speed according to the needle are now only 3/10 mph apart. I don't think I can get closer than that. But... now that it's right, its off. The computer thinks 3.55s when there really 3.27s. I decided to hell with it. I have an appointment to put in 3.73s. They will fix that minor problem. Again, thanks for all of the tips.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Threads Similar to: Odometer Problem Solved -- Thanks for the Help
| Odometer | lwhitetrash88l | V6 Mustangs | 5 | January 26th, 2010 04:13 PM |
| Odometer Problem--Not | Eagle2000GT | 99-04 | 4 | April 16th, 2008 08:42 AM |
| Odometer help please! | militant54 | Audio/Video | 10 | August 18th, 2007 03:24 PM |
| Losing Battery Power Somewhere *SOLVED* | Notcho | 5.0 Mustangs | 20 | November 14th, 2006 02:59 AM |
| Problem still not solved | stang786 | 99-04 | 1 | April 30th, 2006 06:44 PM |
