Steering components problems
LinkBack (1) Thread Tools
Old November 2nd, 2008, 05:38 PM   1 links from elsewhere to this Post. Click to view. #1
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Not sure if this goes along with suspension... close enough I guess...
I have a problem with my front steering... It pulls to the right and makes a rubbing/grinding noise when I steer back left or turn left at all... It won't hold an alignment because I hit a curb pretty hard in FL in the rain about a year and a half ago... A mech. said one time it had a bent tie rod end? I have "visually" inspected both on both sides and can't see any bends.
Any suggestions on how to test certain parts in the garage? I don't wanna pay shop fees for diagnosis. Also, the drivers front tire is wearing down very fast on the inside, but no visible uneven wear on the passenger side.
Is there any chance a wheel hub/bearing has or is going out and making the noises and causing the alignment problems?
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old November 2nd, 2008, 09:35 PM   #2
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
You have been driving your ride for a 1.5 years like this?
Sounds like you bent something under there. Do yourself a favor and pay someone to figure it out and fix it. The cost of the premature tire wear would have probably paid for the diagnosis I am sorry to say.
You could put it up on a lift and do some VERY close comparisons between sides and will most likely find the problem.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids
Tire and Wheel Fitment Guide | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old November 2nd, 2008, 09:44 PM   #3
03 R Code's Avatar
Yeah... the first 12-15 months there wasn't anything noticeably wrong with the driving other than the steering wheel being a little crooked... now it's making a noise and actually pulling to the right... I guess I'm just a little hard headed or cheap. or both.
Old December 5th, 2008, 02:55 PM   #4
2Slow4U's Avatar
2010 Mustang GT
UNK
2Slow4U is on a distinguished road
Send a message via MSN to 2Slow4U Send a message via Yahoo to 2Slow4U
I would be willing to bet that you have a wheel bearing that is shot. ON top of that you probably bent the strut and that is throwing the front out beyond the capabilities of being aligned. I would start with those two parts. They are relatively inexpensive and you could do it yourself if you are fairly mechanically inclined....the only special tool needed really is a spring compressor for the strut....Let me know how it goes...
Old December 5th, 2008, 04:00 PM   #5
2Slow4U's Avatar
2010 Mustang GT
UNK
Was thinking more about your car....while you are checking the strut, check the top spring plate, that may also be tweaked....My wife was ran off the road by a city cop and hit the curb. Had to replace the Hub assy (bearing)m Strut and all hardware on top of the strut to include plate, plastic bushingsm studs and nuts. Good luck
Old December 5th, 2008, 10:26 PM   #6
03 R Code's Avatar
Thanks for the input. I haven't had much time lately to look at it, but it's not being driven much anyhow... I'll check those things out though!
Old January 9th, 2009, 12:58 PM   #7
Moderator
ttt
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/95786-steering-components-problems.html
Steering components problems This thread Refback November 3rd, 2008 06:11 AM
Threads Similar to: Steering components problems
Steering gear box problems!!! bossman69 Classic Mustangs 1 May 30th, 2008 01:13 AM
remember my steering problems??? 03 R Code 99-04 6 December 9th, 2007 07:58 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 09:24 PM
what internal components do i need? bricky77 99-04 12 July 3rd, 2006 10:40 PM
