LinkBack (5) | Thread Tools |
#41 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
its not the motor holding back from turning those rpm's, its the induction. if you had a h/c/i combo that would breathe that high, the stock rotating assembly will do it.
#42 |
Okay, so that answers one of my questions. My other one was, with those heads flowing at say 240 CFM, will my low end torque under 4,000 RPMs still be better than a 4v's under 4,000 RPMs?
My last question was what would the difference be. power-wise, between a 2v and 4v motor if both were pushing 240 CFM, besides the obvious 16 valve difference?
![]() Current mods:
MM Bullitt Crew Founder and Member #1
#43 |
Noob Slayer
13.82 @ 101.09
repeating myself
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
#44 |
mm's nitrous mod
2000 mustang gt
depends on set up. both heads will have their pros and cons, both will give different results under different circumstances. these heads havent even had any chance for review, test, etc as of yet.
#45 | |
The reason I was wondering was because I didn't know if there would be any reason to want a 4v motor if you could have 2v heads flowing just as good. The other thing I asked was right now you see 4v motors running the best 1/4 mile time. With these new heads, assuming you can get them to flow as good as ported 4v heads, would the 2v motors have the potential to run with them? The answer was yes, but once again, that's assuming you can get them to flow that good. My conclusion: The difference between a 2v and a 4v engine is the heads, obviously, and if you can get 2v heads to flow as good as 4v heads, there should be no need for a 4v engine swap. But once again, 4v heads will ALWAYS outflow 2v heads, and they have an overall better design, especially because there's two more valves to help with its breathing. Correct my conclusion if I'm wrong, thanks.
![]() Current mods:
#46 | |
TT Bullitt
![]() iTrader: 2 reviews
However, I don't really keep up to date with whats going on in the 4V world (so this might be wrong), but these heads are going to give us a nice little jump over the 4V's. |
#47 |
Heads/Cam/N2?
Come get some!!
Guys Im sure that these TFS heads will be better than 98% of the competion. Look at my dyno sheet with my new TFS and a ported fast vs stock 243 heads. 243 heads are the best factory LS1/2 heads. Well here is the graph and I have a small cam.
http://www.ls1gto.com/forums/attachm...3&d=1225308647 and here is a vid so ya'll belive me that its a small cam. YouTube - GTO Dyno Pull
![]() Heads/Cam/Maggie 122@8PSI = 364rwhp/402rwtq |
#48 |
amateur adult film star
wont they have issues since the intake valve has been moved to the other side of the head
![]() ![]() performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
#49 |
1997 Mustang GT
Faster than an s4
Just so people are aware. The number of valves is 100% inconsequential to the flow of the heads. In the case of our mustangs, the 4v's are a better design than the 2v's. However, most Big Blocks use 2V head designs. While it seems to make sense to say more Valves = More Flow. That is once again just the flaw of big numbers = big power. It is all the design. If you have only 2 paths for the air to follow, and the path is optimum, your flow will be better. The true most efficient system you could have would be to have 1 valve and it would do one and then magically the other. This way you would have perfect efficiency of flow. The problem is, thats impossible. The point is, don't think that 4v means more flow ALWAYS. It is true in our cars now, but not necessarily forever.
As a reference there are heads made for our cars that are a perfected version of the ones NASCAR's use. They flow something like 800cfm at .55" of lift. They cost like $8k a set but they are like the best you can buy. And yes, they are 2V. Keep that in mind, flow is what matters not the number of ports.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
#50 |
...where can I find these magican 2v Mustang heads flowing at 800 CFM? Links?
![]() Current mods:
#51 |
2003 GT
Also, keep in mind that more flow isn't always better for performance. There are a lot of guys running heads that don't flow as much as another yet they blow doors!
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles |
#52 |
I'm just pissed they didn't announce these just 6 months ago. I might have actually paid the extra money for them.
2000 GT 665/540rwhp/rwtq On pump gas Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA |
#53 |
i will be selling a portion of my liver to buy a set of theese head i cant wait
#54 |
not yet captured
Looks like good times =) These with a nice cam seem like a viable N/A option finally. I don't wanna reduce the life of my engine with a blower. And on a side note my GT doesn't stop pulling at 5,800. I have heard so many people say this. I have two good friends with Machs and my little 2V pulls nearly as hard at the top. Obviously the 4V has more power overall but it's not as significant as I hear a lot of other people saying. I have never dyno'ed or tracked my car but the mach I drove dyno'ed 305 and it is def a bit quicker but he has a real hard time showing me his tails. Is my car a freak? I have never driven another 99-04 GT. I did stay neck in neck with my other friends S197 as well. I just wish it rev'ed ot to 7K like the mach...=)
2000 Mustang GT Silver on charcoal MMR Coilover kit, FRPP 4:10's, SCT box tune, FRPP King Cobra Clutch, Steeda quick release quadrant on FRPP cable, MGW shifter, K/N cold air intake, Flowmaster exhaust [SIGPIC] |
#55 |
2000 GT
A stock or mostly stock gt stops making power at about 5800. It still pulls but it is now out of the power band. Your car is doing good probably because of the 4.10's which help a lot. Is your buddys mach stock?
And power is power. 100 hp from heads and cams will stress the motor the same as from a blower. The more power the more wear.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#56 |
1997 Mustang GT
13.56@102.94
Sweet!
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
#57 |
I saw these heads in person at Sema this week. Seem pretty impressive, Ill post pics later. Seem to be the best desgin Ive seen, and I saw thier new intake for the 2V also.
#58 |
again would there be an issue with the intake valve being on the other side of the cam shaft from what it usually is
#59 |
mm's nitrous mod
2000 mustang gt
supposedly, not suppose to be. all stock hardware is suppose to work just fine.
#60 |
i mean the cams only spin in one direction and it looks (to me )like it wouldn't work
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/96149-trick-flow-2v-heads-ftmfw.html
| Get in Line! Trick Flow 2v heads coming! - Page 84 | This thread | Refback | August 4th, 2011 02:17 PM | |
| Get in Line! Trick Flow 2v heads coming! - Page 154 | This thread | Refback | August 3rd, 2011 08:21 AM | |
| What heads should I run in my 2002 ROUSH Mustang Stage 2 - Ford Mustang Forums | This thread | Refback | April 2nd, 2010 11:36 AM | |
| trick flow 2v heads FTMFW!!! - Page 5 | This thread | Refback | December 17th, 2008 11:16 AM | |
| trick flow 2v heads FTMFW!!! - Page 4 | This thread | Refback | November 7th, 2008 11:10 PM | |
Threads Similar to: trick flow 2v heads FTMFW!!!
| Trick Flow Heads | acmillr | 99-04 | 116 | February 24th, 2009 03:44 PM |
| Looking to get New Heads - Trick Flow or AFR's? | The Novice | 5.0 Mustangs | 21 | October 24th, 2008 01:04 AM |
| trick flow heads fs again | flattusmaximus78 | 5.0 Mustangs | 6 | March 28th, 2008 08:32 PM |
| whats the cfm for trick flow heads | White Thunder | 5.0 Mustangs | 44 | October 18th, 2007 10:59 PM |
| Tuning Issues 5.0 w/trick flow heads | 1slowhatch | 5.0 Mustangs | 2 | April 23rd, 2007 12:56 PM |
