Discussing Difference in Gas Mileage Between 3.73 and 4.10's in the 99-04 Forum. Originally Posted by SilverGT04 so how long does it take to break gears in and ...
Old January 6th, 2008, 08:04 AM   #141
Editor
Smoothgrandmama's Avatar
Originally Posted by SilverGT04 View Post
so how long does it take to break gears in and how much more does 4.10's pull than 3.73
Not Long I didn't break mine in at all!
Old January 8th, 2008, 09:00 AM   #142
GRAB_THS's Avatar
2004 Musang GT Conv
dunno yet...
Originally Posted by Juggalo_X View Post
yep even at higher rpms. installing a steeper gear set puts more torque down. it doesn't add any just gets it to the ground better. there for your engine works less to keep a higher rpm.
What I was getting at....
04 Gt Vert - 5 spd
Pypes Off-road X,
JLT CAI,
C&L Plenum,
Mach1 Chin Spoiler,
Mach1 Grill Delete,
4.10's,
Xcal2
More to come....someday in the 5 year plan
Old January 13th, 2008, 08:53 PM   #143
I had 3.73's in mine not bad better than stock. now I'm going right to the 4.30's who gives a shit about gas mileage it's a mustang there made for hauling ass. when u run out of fuel ya just put more in. If u have to ask about milage in a stang then your not worthy of driving one. please sell it to a real stanger and get a volkswagon bug disel. my queer boss say's he get's 50 miles to the gallon. yipie looser
Old January 17th, 2008, 08:24 PM   #144
i went from 3,55s to 3,73s and lost 2 mpg. i cant get 20 anymore. i got 22 at best with 3.55. i cant get over 19.4 now with 3.73s and staying out of the boost
my car would still pull good with some 3.27s. and might get 24 mpg
Old January 22nd, 2008, 10:09 PM   #145
I barely make 200 miles per tank in my 00 gt
00' GT Few boltons and full uxhaust including shortys
Old February 2nd, 2008, 06:17 PM   #146
bogdans01gt's Avatar
2001 Mustang GT
definetly a great post, i had 3.73's 2 weeks ago and now i switched to 4.10's definetly no difference in gas......
Old February 6th, 2008, 03:09 AM   #147
mystang0673's Avatar
13.0@104
just get 4.10s
Old February 9th, 2008, 12:24 AM   #148
takiller's Avatar
2003 Mustang GT
no clue
with stick gears i can barely get 290 miles to the TANK. wheni had 4.10's i could get in the 312-320 mile to the tank depending on driving . the whole thing about your going to get horrible gas mileage is like a myth man. you have more power at lower rpms, right? SOOOO that means you can shift a lot earlier and still have PLENTY power to get through the gears. and if you shift at low rpms's then you save on gas. BOOM!! theyre you go, 1st hand experience.
What was that you were saying about power to weight ratio?
Thats what I thought.
Old February 10th, 2008, 10:24 PM   #149
Anyone running 4:10's on an auto?
Old February 15th, 2008, 05:51 PM   #150
2004 SVT Mustang Cobra
Question
add to question about gear swap...
I was getting ready to post a thread on this topic when I noticed this one. I wanted 4.10's but my tuner said that I may be better off with 3.73's since I mainly drive it on the street and it isn't only a track car. I am pulling 16lbs boost and although I have the new MT ET Drags, traction is still an issue. It just doesn't seem like there would be a big difference from stock 3.55 to 3.73? But then how much difference between 3.73 and 4.10?
2004 Terminator Cobra #45
Triple Black
16 lbs boost with various mods
Old February 17th, 2008, 01:23 AM   #151
Volstang's Avatar
2004 Mustang GT Convert.
Originally Posted by mdvaldosta View Post
Top speed isn't gonna go down, as the stock gearing is gonna put you way higher than what the car's capable of anyways. In fact, top speed will probably go up switching to 4.10's as you'll be higher in the powerband where you'd need it to keep accelerating. At any rate, at 70mph in 5th gear you'd probably be around 2600 rpm's. In my 2002GT I'm at 2400rpm at 70 but my overdrive is a tad smaller than yours.
Uh top speed is topped out speed so there is no acceleration so goes the saying TOP SPEED. and it does loose it with lower gear whether its a car, bike, boat, whatever.
Old February 17th, 2008, 07:17 AM   #152
medic_chris85's Avatar
2001 Mustang GT Vert
I am
01 GT ***New Addition, Vortech V1 S trim waiting on me to get back to put it in.***
<a href=http://www.moddedmustangs.com/forums/signaturepics/sigpic13190_2.gif target=_blank>http://www.moddedmustangs.com/forums...pic13190_2.gif</a>
Old February 17th, 2008, 11:39 PM   #153
2004 mustang gt
keep the 4.10's
Old February 24th, 2008, 01:35 AM   #154
RanGer498's Avatar
2001 Mustang GT
UNKown
Question
Originally Posted by cliffyk View Post
Tires sizes are specified as the tread width/aspect ratio-wheel diameter--the aspect ratio is the ratio of the sidewall height to the tread width, specified as a percentage...
So, a 245/45-17 has a tread that's 245 mm wide, an aspect ratio of 45, and is meant for a 17" wheel.
245 * .45 = 110.25 mm, so we know the sidewall is 110.25 mm high, add the sidewal height * 2 to the wheel diameter and we find that this tire is 110.25 * 2 + 17 * 25.4 or 652.3 mm, or 25.68" which is pretty close to the 25.7" most manufacturers state.
Now lets do a 275/40-17, 275 * .4 = 110 mm, 110 * 2 + 17 * 25.4 = 651.8 mm = 25.66" (again pretty close to 25.7").
OK, now let's do the math for a 225/45-17; 225 * .45 = 101.25 mm, so a 225/45-17 tire is going to have an outside diameter of (101.25 * 2 + 17 * 25.4) = 634.3 mm = 24.97" (25" is the quoted spec).
That's how you change tire diameters--buy tires of a different diameter...
what about 315/35/17s?
same questions
Old February 29th, 2008, 08:38 PM   #155
10.67 @ 125.45
This Is A No Brainer Question. Lower Gear Will Drop The Gas Milleage Some, But If You Would Like To Win Races Then Who Cares.
The Best Rule Of Thumb I Have Heard Is 3.73 For Stick, And 4.10's For Auto. I Run A 4.10 With A Manual Valve Body Tranny. Love It. Drive It On The Street, And Run L0w 10's At Track. Heck We Pay $7.00 For Race Gas, So Money Better Not Matter That Much. ( I Am Not Rich Either.)
Car with new motor is great. Now runs mid 10's on Motor, and ran a 10.012 on a 50 shot of NOS. Got thrown off 1/4 track, so will just run the 1/8 NO CAGE. JUST A ROLL BAR. LIKE TO STREET DRIVE IT,SO WILL NOT INSTALL CAGE.
Old March 5th, 2008, 07:15 PM   #156
373s for the win
Old March 5th, 2008, 07:15 PM   #157
best all around gear by far
Old March 5th, 2008, 08:44 PM   #158
njstang's Avatar
14.20@98.61
so what about 1/4 mile differences? is there a big difference in et's between the two gears??
Old March 7th, 2008, 06:41 PM   #159
RALVAREZ26's Avatar
2000 MUSTANG GT
14.2@96.53
everyone's talking about 3:73 and 4:10 but what about 4:56's? anybody in this board has some?
http://smokinperformance.com
'00 GT cai,x-pipes w/flowmaster dumped, sct tune!
Old April 7th, 2008, 12:01 AM   #160
interfac9's Avatar
1999 Mustang GT
I put 4.10s on mine, and it was the best thing I ever did!!! Boy did she wake up... I highly recommend them.
Building a better mousetrap only makes smarter mice....
Threads Similar to: Difference in Gas Mileage Between 3.73 and 4.10's
gas mileage haywood11 5.0 Mustangs 56 October 28th, 2007 10:45 PM
Difference in gas mileage between a GT and a Cobra Mistertribal 99-04 30 August 10th, 2007 05:53 PM
Gas Mileage!!!!! HELP theyanks904 V6 Mustangs 20 July 20th, 2007 07:23 PM
V6 gas mileage Racerchik02 The Clubhouse 62 June 12th, 2007 07:23 PM
gas mileage! CBSTANG 99-04 48 March 24th, 2007 12:52 AM
