High Idle
so i put a IAC restrictor in my car cuz i hated how the rpms would hang up, it worked mint for about a week.. then the damn thing started idling high i did everything to try and get it back down but nothing worked, i took the restrictor out and it still idles around 2,200 rpms. it drives me fuckin insane. i can let the clutch out and shift up to 5th gear with out touching the gas and cruize at 60 mph. how the hell can i get it to idle around 1000 again??
96 GT , cams,intake manifold,CAI,Exhaust,Full Hotchkis suspension, and many more |
Resident Bubblehead
try cleaning out your IAC with some carb cleaner. i had problems like yours too and i wound up having to replace the throttle position sensor. after that, i had no problems at all
mine most of the time idles to high, every now and then its normal for a day or so then its right back up and i get pissed off again
clean it out good
1999 GT Rag
wow, 2.2k rpm... i idle nicely at about 500.
def. clean the iac. |
did you mess with the idle screw at all?
is it normal to have all kinds of black shit in your plenum? i had the CAI off from the throttle body and i was looking in to see where the butterfly was closing and i noticed just passed the TB is all black and when i took the IAC off i stuck my finger in there and it was coated in black shit..like burnt up engine sledge shit, I cleaned out the pcv valve but it seemed to be free when i took it out, il try cleaning out the IAC and Il let ya know, if that doesnt help any other suggestions??
#8 | |
slight noob question while roughly on topic (saves posting a new thread)... IAC will solve the annoying inconsistent idle? Mine goes from 1000 to 500 RPMS on a consistent basis.. Its annoying... IAC fixes that? Price? Install difficulty?
how bout inspecting the idal set screw see if it has wiggled out a lill
check the idle screw but thats not where your idle is adjusted from, the idle is in the computer. and to answer the noobs ?, yes it should fix it and you can do it yourself for the price of some carb cleaner
Threads Similar to: High Idle
| high idle then nothing | msolaas1 | 2005 - 2010 | 4 | October 10th, 2007 05:42 AM |
| High idle | 8A_Honda | 5.0 Mustangs | 16 | September 17th, 2007 07:53 PM |
| high idle | buddie | 94-95 | 1 | June 30th, 2007 02:40 PM |
| Idle Too High | terribleonexx88 | 5.0 Mustangs | 28 | October 15th, 2006 11:27 PM |
| Idle Too High | DaveCarey | V6 Mustangs | 14 | October 11th, 2006 11:17 PM |
