my a/c is not working
does someone know where can i take my car to get the a/c check because is not cooling at all
The Mean Green
Dealership or most maintaince shops can check a/c. Did you check all your fuses first? Can you hear the compressor kicking on?
1997 Mustang GT
Faster than an s4
It could be a list of things. Check if you hear or feel it on first. Then check if it needs a recharge. Best case you just need a recharge. Worst case, the compressor is bad.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
2002 MUSTANG GT
14.2@100
its probably a leak somewhere in the system. its usually the condensor but it could come from any one of the lines. or the compressor itself could be bad. you can go to the autoparts store and get a A/C charging kit for 20$ and see if it will hold. you can also check to make sure you compressor is good as well because if you system is low on frion the compressor wont kick on. so when you turn your A/C on and fill the system the compressor should kick on. let me know if that helps you! good luck
Just go with an AC delete. Then go long tubes and mac prochamber. Texas isn't that hot. lol
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
The Mean Green
Threads Similar to: my a/c is not working
| Just got home from working... | Dansby | The Clubhouse | 39 | March 16th, 2008 02:50 AM |
| speedometer not working | aries24js | 96-98 | 1 | August 23rd, 2007 11:33 PM |
| AC not working | chuck&monika | 2005 - 2010 | 5 | August 6th, 2007 01:33 PM |
| tailights not working help please | dragpipe | General Tech | 2 | January 15th, 2007 04:53 PM |
