LinkBack (1) | Thread Tools |
13.6@100.38mph,(before tune)@3300ft elevation
Car wont start! loud clicking only!
I got in my car to start it today and all it would do is click loud and repetatively. It doesnt even try to turn over.Does that mean my starter is screwed?
Mac LT'S,BBK CAI,BBK Throttle body.trick flow plenum,1inch throttlebody and plenum spacers 75mm,95mm maf,underdrive pulleys,4.10 gears,King cobra clutch,t56 transmission,pro 5.0 short shifter,aluminum cobra driveshaft |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
or your battery is real low
yep get u a new one,its not kicking in...try hittin the stater with a bar an see what it does, is ur battery good an charged
The battery was charged. I even had the charger hooked up still! Damn Im going to the desert next month so i really dont feel like changing that.my longtubes are real close to it.Its gonna be a b**ch to do. I might just wait til i get back.
2000 GT
Look at the voltage gauge. Or turn on your lights and check how dim they are. If you turn lights on and gauge moves, battery is low! If gauge isnt at or above half its low.
Has it been sitting for awhile? Has it had any issues starting lately? (long cranking or having to rev it while cranking). When it gets colder, worn and abused batteries crap out.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2000 GT
In that case, check grounds. And are the terminals corroded at all? and as said earlier try hitting the starter with a rubber mallet. Might of got stuck. And make sure connections are good to it.
just sounds like his bendix in the starter aint kicking in,it may help if he beats on the stater with a bar or something,then it may kick in.
It was sitting for 5 days and the batt usually dies when it sits for more than 3days. Is it poss that its the batt.I had the charger on it and it didnt even try to turn over.Ill bang on it 2mro and hopefully that will work.
ruber mallet hell beat that bitch with a sledge hammer an pry bar lol j/k
it should start if u have had the charger on it for awhile,make sure its gettin a good connection. chagers should start it even if its dead...an dead battery an bendix not kicking in sounds about the same
I prob need a battery regardless.Im tired of that shit being dead every time it sits for a few days.If my starter is fucked do they make ministarters for our cars.
2007 MUSTANG GT
the battery is junk from being drained 1 to many times.
I figured it was crap.
2007 MUSTANG GT
Take it to Auto Zone to have the battery checked to be sure.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
ya get a new batt for sure. like the guy said the bendix wasn't pushing all the way out. The magnetic field on the starter seloind* may have a weak magnetic field and the magnetic field around it pulls the bendix out to the flywheel. if not enough juice in the battery the clicking is the bendix going out a little and then back b/c the magnetic field it's strong enough to push all the way out and that in turn won't spin the flywheel near fast enough to start your engine. so try getting a new battery.
I'd get the battery checked first. Usually if the bendix is shot, the motor will still spin, it just won't engage the flywheel. The continuous clicking usually means no juice. Have the battery checked, and do like Ryan said, check the starter cable to make sure its not rubbing on anything like the long tubes or something.
I will take the batt 2mro to see whats up.thanks for the help guys
Good luck. Hope thats what it is and not the starter motor itself.
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
my car does too. if it sits 2-3 days.. she done
Do you get a little spark when you disconnect the neg cable? If so, then you have a short or closed circuit somewhere which is draining it.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/96936-car-wont-start-loud-clicking-only.html
| Car wont start! loud clicking only! - Page 2 | This thread | Refback | November 11th, 2008 09:38 PM | |
Threads Similar to: Car wont start! loud clicking only!
| Car Wont Start? | Trent-04v6 | Audio/Video | 8 | February 20th, 2008 01:26 PM |
| car wont start | 1BADSTANG | 5.0 Mustangs | 12 | January 14th, 2008 02:01 AM |
| car wont start | Black Five 0h | 5.0 Mustangs | 8 | January 4th, 2008 04:12 PM |
| car wont start.. | soop7 | V6 Mustangs | 3 | December 1st, 2007 04:18 PM |
| Need Some Help - Car Wont Start | ANoXiA | 2005 - 2010 | 6 | December 23rd, 2006 07:07 PM |
