Cracked Lower Control Arm Bushings
LinkBack (1) Thread Tools
Old November 11th, 2008, 06:53 PM   1 links from elsewhere to this Post. Click to view. #1
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
EDIT: I ment to say cracked lower control arm bushings.
The rear end seemed to keep making a clanging noise and I couldn't determine where it was coming from. Check the Lower control arms and I find out they are all completely trashed. The bolt was riding directly on the steel part of the arm.
Called MMR and they sent me brand new bushings for free and even payed for shipping. After hearing all the MMR horror stories I thought they would do anything for me, anyways heres a few pics of what happened.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old November 11th, 2008, 07:07 PM   #2
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
wow... sucks but glad you found it before it did more damage
Old November 11th, 2008, 07:14 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Just curious how did you get the bushing out?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old November 11th, 2008, 07:48 PM   #4
1999 GT
iTrader: 7 reviews
Took a razor blade and cut the bushing even with the metal and then took a punch and rubber mallet and banged it out of place.
Old November 11th, 2008, 07:48 PM   #5
1999 GT
iTrader: 7 reviews
Yeah good thing I changed it out now, I planned on going to the track this weekend...
Old November 11th, 2008, 08:50 PM   #6
not yet captured
SilverFreakGT is on a distinguished road
how do you like those MMR control arms? According to what I have been hearing the poly bushings will still allow binding. So in order to really reign in the back end you have to go to a spherical bearing on one side or both sides. Can anyone confirm this? Also, is there a way to make the quadshocks fit with coilovers? I had to yank mine due to clearances which made axle hop a big problem haha
Silver on charcoal
MMR Coilover kit, FRPP 4:10's, SCT box tune, FRPP King Cobra Clutch, Steeda quick release quadrant on FRPP cable, MGW shifter, K/N cold air intake, Flowmaster exhaust [SIGPIC]
Old November 11th, 2008, 10:50 PM   #7
13.00 @ 105
that is what I had ( MUSTANG-UPR Products.com ) and everyone I know that has done the coilover/control arm setup ditched the quads
Old November 12th, 2008, 12:00 AM   #8
not yet captured
that's what I've heard, they have an obvious benefit though, wish I could use them... oh well, control arms should do fine without them
Silver on charcoal
Old November 12th, 2008, 08:52 AM   #9
Randy Stinchcomb's Avatar
1996 Mustang GT coupe
11.99@113.93mph
Randy Stinchcomb will become famous soon enough
one thing you need to check:
1999 up Mustangs use 14mm hardware to mount the lower control arms, where 1979 to 1998 only used 12mm hardware.....
now the lower control arms are pretty much the same from 1979 to 2004, excecpt for the ID of the bushings and sometimes the companys that sell those arms include the hardware thats 12mm instead of the 14mm bolts & nuts that are used on 1999 to 2004 and that 2mm smaller diameter bolt could have caused this, so I'd get new 14mm hardware from the dealer....
Thumbdinger.com Fish With Protection
Old November 12th, 2008, 09:16 AM   #10
11.99@113.93mph
also as someone else pointed out;
where are the metal sleeves that are suppose togo thru the rubber bushings?
Old November 12th, 2008, 11:14 AM   #11
13.00 @ 105
+1 i didnt even realize they werent there...
also, on the 12mm vs. 14mm bolt issue...if they sent you the 12's by mistake, dont try to use them for a temporary fix... wait on the 14's (or buy some)
its obvious if you try to use the 12mm bolt in the 14mm hole... my brothers cobra had 12mm bolts in the front of the IRS and everytime he would accel/decel it had a loud pop from where the bolt was moving around in the oversized hole
Old November 12th, 2008, 01:03 PM   #12
1999 GT
iTrader: 7 reviews
I installed what they sent, with that said I will be soon upgrading to these.,,
And this for the upper
btw: these are made by baseline suspension
Old November 12th, 2008, 01:17 PM   #13
11.99@113.93mph
ok but not the best choice for a D/D and your gonna' have alot more maintenance wth those along wth more NVH, a need to have your TQ boxxes weled-up and you'll have to keep tabs on the rear pinion angle....
Old November 12th, 2008, 01:23 PM   #14
1999 GT
iTrader: 7 reviews
Ehh doesnt bother me, I do DD the car but I don't have far to go with it. The TQ boxes will be welded up as soon as I finish my intercooler set up since i'm gonna have to rent the welder
Old November 12th, 2008, 02:20 PM   #15
13.00 @ 105
I've heard nothing but good from baseline suspension products (my buddies fox was a test dummy for some of their stuff)
its going to be a little more on the noisy side though
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/97085-cracked-lower-control-arm-bushings.html
Cracked Lower Control Arm Bushings This thread Refback November 12th, 2008 11:34 AM
Threads Similar to: Cracked Lower Control Arm Bushings
Control Arm Bushings 89StAngerLX 5.0 Mustangs 8 May 3rd, 2008 12:04 AM
lower control arm bushings noppe180 96-98 5 November 7th, 2007 06:09 PM
Control Arm Bushings? CMcD 5.0Lx93 5.0 Mustangs 5 August 8th, 2007 12:37 AM
control arm bushings angermgt 5.0 Mustangs 5 May 15th, 2007 07:30 PM
Lower Control Arm Bushings cali 5.0 5.0 Mustangs 3 November 13th, 2006 06:04 AM
