Got my cc plates on
Old November 12th, 2008, 12:42 AM   #1
Whatever it originally would be
Seabee's Avatar
05 Saleen #824
Fast as fuck
Seabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to behold
Send a message via AIM to Seabee
Got my cc plates on
how do you know what is a good degree to put shocks at? How much adjusting do you guys actually do, or do you just let the shops align them and dont touch it? I also put on Tokico 5 way adj. struts on the front, with my springs.
MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Old November 18th, 2008, 09:18 PM   #2
Racinjason81 is on a distinguished road
you should work close to alignment specs to stay outta trouble.you might wanna add some negative camber (moving strut toward the back of the car) to increase high speed stability and maybe some negative camber(moving strut towards engine)to increase front grip.By adding negative camber you wear the tires on the inside more.add a degree
more negative caster and a half a degree more negative camber for the street.You may also wanna ask Maximum Motorsports or Kenny Brown on a good alignment setup.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old November 18th, 2008, 09:22 PM   #3
If you didnt add them already you should install a k member brace and a strut tower brace to limit the flex that can change your alignment since the strut towers and k member definitely flex a good amount
Old November 18th, 2008, 09:38 PM   #4
Seabee's Avatar
05 Saleen #824
Fast as fuck
i was going to buy the strut tower brace, i just gotta make sure i will have enough money after i buy it. I still get confused on the whole degree thing
MILITARY CREW
Old November 18th, 2008, 09:42 PM   #5
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Originally Posted by Racinjason81 View Post
you should work close to alignment specs to stay outta trouble.you might wanna add some POSITIVE CASTOR (moving strut toward the back of the car) to increase high speed stability and maybe some negative camber(moving strut towards engine)to increase front grip.By adding negative camber you wear the tires on the inside more.add a degree
Not to be picky, but may cause some confusion to the OP.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old November 18th, 2008, 09:45 PM   #6
Abyssinian of AX
'02 Saleen
19.34@42.259
Don't recommend the strut tower brace, but rather sub-frame connectors and tubular "K" member if you want to improve strength of chasis.
What are your goals for your ride in this reguard?
Jazzer minds want to know
Last edited by Jazzer The Cat; November 18th, 2008 at 09:46 PM. Reason: clarification
Old November 18th, 2008, 09:45 PM   #7
definitely a good idea if you got the cash.what exactly confuses you maybe i can clear some of this up.
Old November 18th, 2008, 09:50 PM   #8
Seabee's Avatar
05 Saleen #824
Fast as fuck
well i want even wear on the tires, so it would have to be flat on the ground, straight up and down. And if im getting it aligned, should i even mess with it?
and to Jazzer, im not too worried bout the k member. Ill be putting on a supercharger eventually, and some more engine work, head cams mainly. But not really going for track worthy
MILITARY CREW
Old November 18th, 2008, 10:04 PM   #9
a half a degree more negative camber would give you more grip up front and would cause the tires to wear a very minimal amount more than normal. dont forget to add no more than a degree more negative caster(does not affect tire wear) if you want the car to be more stable at speed. you should take advantage of the C/C plates.
Old November 18th, 2008, 11:02 PM   #10
Seabee's Avatar
05 Saleen #824
Fast as fuck
yea but how do i know how many degrees it is?
MILITARY CREW
Old November 19th, 2008, 11:23 PM   #11
when you get it aligned they will have it on the print out.just tell the tech who aligns your car how much want to add in degrees
Old November 20th, 2008, 02:58 AM   #12
Seabee's Avatar
05 Saleen #824
Fast as fuck
thats what i figured, thanks. I need to find a place now
MILITARY CREW
Threads Similar to: Got my cc plates on
3 or 4 bolt CC plates AndrewA. 99-04 5 June 25th, 2008 06:38 PM
The Best CC Plates? VinceSVT 99-04 11 March 13th, 2008 03:22 PM
Do I need CC plates? HessiaN257 Modular Mustangs 3 October 31st, 2007 12:54 PM
CC plates nolife 5.0 Mustangs 3 July 27th, 2007 05:05 PM
