Discussing What Cam? in the 99-04 Forum. I have a huge list of mods going in over the winter but I can'...
Old December 18th, 2006, 05:25 PM   #1
What Cam?
I have a huge list of mods going in over the winter but I can't decide on the cam. What you see in my sig is what I have and here is the list of what is coming.
Patriot Stage II heads (save your flames for another thread please)
4.10 gears
Tubular K member
Tubular A arms
Front Coilovers
Adjustable Upper Control arms
A lot of people say Comp Cams 262...I like to go a little bigger then the norm and have been thinking 270's...
What do you guys think?
2002 True Blue Mustang GT M5
Check garage for modsStainless Works First prod LTs, X Pipe, Turbo Muffs
Dyno-310hp 320T
2004 GTO
Dyno–419RWHP 394RWT
Old December 18th, 2006, 05:30 PM   #2
sonicblue's Avatar
1990 GT
theres nothing wrong with patriots so dont listen to anyone about that. i know a few people that run them with a lot of success. i agree i would go a little bigger than the 262s. sounds like a good little winter project you got goin on
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old December 19th, 2006, 11:45 AM   #3
I forgot to add subframes to the list.
Dyno-310hp 320T
2004 GTO
Dyno–419RWHP 394RWT
Old December 20th, 2006, 05:25 AM   #4
being that you have the heads, do the comp 270's or vt stage 2 cams
Old December 21st, 2006, 05:43 PM   #5
I was thinking 278....not sure still. It was easier picking a cam for the Goat... Go big or go home. Love that lopey sound! And pulls like a raped ape and like I have nos when I hit 4k rpms....nothing like it!
Dyno-310hp 320T
2004 GTO
Dyno–419RWHP 394RWT
Old December 21st, 2006, 10:19 PM   #6
the 278 cams will make the valve hit the piston if you dont have valve release
Old December 22nd, 2006, 02:43 AM   #7
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
VT's or MPH cams...
My Junk
www.myspace.com/cjobe
Old December 22nd, 2006, 09:49 AM   #8
The flow #'s that are put out by those heads are higher than a 75%(88.5% to be exact) flow ratio and you are going to want a "reverse split" or more intake duration than exhaust. Due to the restrictied cylinder volume and poor head designs these engine seem to prefer a smaller cam, will call the middle of the road rather than small. If your going to spend the money you may want to consider a custom cam for your application.
Here is something I suggest you look at:
270 adv. I duration
264 adv. E duration
.555"max lift Intake
.555"max lift exhaust
113 or 114 LSA
On a 110* intake centerline this cam will give great clearence (ptv) and probably net 5-10 rwhp over a generic off the shelf cam.
Again without a flowchart this is only going to be close as I went from Patriots advertised flow numbers.
Old December 23rd, 2006, 04:58 AM   #9
Fryrice's Avatar
VT2 all day ,everyday.
Fryrice has left the building.
Old December 23rd, 2006, 10:47 PM   #10
The actual flow numbers came out like this...
Int
.1 - 65.9
.2 - 119.1
.3 - 160.5
.4 - 190.2
.5 - 212.9
.55 - 217.5
.6 - 221.2
Exh
.1 - 54.9
.2 - 102.3
.3 - 138
.4 - 162.6
.5 - 180.1
.55 - 185.9
.6 - 190.9
Dyno-310hp 320T
2004 GTO
Dyno–419RWHP 394RWT
Old December 23rd, 2006, 11:19 PM   #11
Int
.1 - 65.9
.2 - 119.1
.3 - 160.5
.4 - 190.2
.5 - 212.9
.55 - 217.5
.6 - 221.2
Exh
.1 - 54.9
.2 - 102.3
.3 - 138
.4 - 162.6
.5 - 180.1
.55 - 185.9
.6 - 190.9
I still suggest the same cam, the flow numbers are to the same ratio or close. The profile I gave you will have huge gains in the middle and upper rpms and will pull from 3300-6600 after that you'll run out of intake. You will need to upgrade spring and be sure to degree them. AS I said these will work better than a generic cam as they are profiled more to your set-up. You can buy a cam everyone has or get one that is set for your needs.
Again with those exhaust numbers you'll want something to favor the intake. You'll make more power with a custom grind over any generic cam... I'll stop at that.. let me know if you need anyfurther info.
