2001 mustang bullitt
brake rotors
i have an 01 bullitt im looking to add some bigger back brakes...is there any way i could put the same rotors on the back as go on the front? i havent been avble to find any bigger ones for the back anywhere
2001 gt
No you cant. The only thing you could do is a aftermarket brake system(brimbro,wilwood,ect).
Have you done anything with the front brakes yet? I did slotted rotors front and rear with pads for a little over $200. I got them from Rotorpros.com Most of your brakeing is done by the front. Your back brakes are/should be smaller then the fronts or you not going to be brake right. How much HP are you putting out?
well it came with the cobra f+r brakes on it..i was just looking for something a little bigger in the back to fill the wheel out more but i dont have money for a big kit or anything i think im just going to replace them with these in the front and rear 94-04 FRONT ROTOR, COBRA/BULLITT/MACH 1 LH, BIG BITE DRILLED/SLOTTED/PLATED MUSTANG
Resident DJ
'01 Cobra Vert.
I would upgrade the just the rotors man. 11.65 is a decent size for the back and 13's are the shit for the front. I put some Brembo's slotted all the way around on mine and it made the world of a difference compared to the stock. I'd look into just upgrading the rotors and keep the size the same.
Who cares, the back brakes are only responsible for 20% or less of the braking, the fronts do all the work. Just get better pads and rotors for the rear, thats all you need.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
Unless you are running some BIG HP you don't need to get bigger brakes. The cobra brakes you have on right now are more then enough for the car. Get better rotors and pads if you want to stop better. Filling out the rim in the back will make the car not brake right and will look kind of silly. Most people know that the rear brakes are smaller then the fronts.
just upgrade the rotors and pads
I wouldn't go with crossed drilled and slotted. They are more like the crack. Slotted is a better way to go. ROTORPROS - Home Page This is where I got my slotted rotors and pads front and rear for about $220.
And you can get them colored if you want.
2001 gt
No the front only does about 60-65% of the stopping. Check out EBC. They make a slotted and dimpled rotor that looks cool.
TT Bullitt
![]() iTrader: 2 reviews
IMO there is not much that can be done to improve the braking system, unless you are looking at replacing the entire system with say 6-piston calipers.
This coming from a fellow Bullitt owner also. You can get cross drilled/slotted just know that those are for looks only. Making the brakes larger in the back is going to do nothing but add rotating weight, slowing you down. |
kk thanks
2002GT Vert.
![]() iTrader: 1 reviews
don't do drilled for the street.maybe slotted. i upgraded to the 13" severe duty rotors from ford on the fron along with the bullitt calipers and it works awesome.
![]() 02 GT vert-True Blue w/Black staggered FR500's Trick One springs. MGW shifter. Flowmasters. Steeda Wing. Mach 1 chin/grille. CAI. Pulleys. SCT Tune.+ more in the boxes waiting to go on. Topless Mustang Club |
2008 Cadillac CTS4
when i upgraded just the pads and rotors on my old stang it made a nice difference, just go with that and put the saved $$$ some where else
2001 gt
Just check out EBC. They make a slotted and dimpled rotor.
Drilled rotors are more likely to brake or crack then slotted. You would want drilled and slotted rotors if you only race your and don't drive on the street. D+S rotors are made to keep the brakes cooler under hard brakeing condition, I.E. raceing on a track. You will get more out of slotted rotors for the street then you will with D+S rotors.
#20 | |
2002GT Vert.
Threads Similar to: brake rotors
| brake rotors? | 97GT4.6 | Modular Mustangs | 9 | January 18th, 2008 12:52 PM |
| brake rotors | Badasstang281 | 99-04 | 4 | December 23rd, 2007 10:56 PM |
| Best brake rotors | neckbonekat | 99-04 | 4 | August 28th, 2007 03:31 PM |
| Brake rotors | Stangzilla | 5.0 Mustangs | 5 | May 8th, 2007 09:59 PM |
| brake rotors?? | burnout5.0 | 99-04 | 3 | April 13th, 2007 11:12 PM |
