2003 GT
Possible rear end problems
So I just went on a road trip and when I stopped to get gas after 300 miles of driving, I noticed a whine or a moan coming from the rear end when I turned sharp. I proceeded to finish my 1200 mile round trip with each time I got off the freeway to get gas the sound got worse...It has progressed to the point where it sounds like the limited slip is stuck/locked up, and when I turn it busts loose and makes all kind of racket followed by the moan. Any suggestions on what it might be?
StangSuspension.com Series II 2 inch lowering springs, MM Caster Camber Plates, MM Strut Tower Brace, Steeda Bumpsteer Kit, Steeda Clutch Pedal Improvement Kit, Fidanza Aluminum Flywheel, Centerforce Dual Friction Clutch |
1996 Mustang GT coupe
11.99@113.93mph
any signs of fluid leaking from the pinion seal, axle shaft seal(s) or at the axle tube vent?
how many miles on it? have you checked the fluid level lately?
Thumbdinger.com Fish With Protection
2003 GT
No fluid leaking...it has 71k on it and it is my daily driver, I have never heard that noise before and no I havent checked the fluid level yet. I kind of figured that it might be low and that long drive just heated it up to a point where the clutches stuck together....not sure though
11.99@113.93mph
yeah, well I'd bet it's either low on fluid, the fluid is worn-out, or both as the rear diff is supposed tobe serviced at @30k intervals under normal use, so your way-way over due.....
2003 GT
haha wow, yeah I guess im gonna have to do something about that...hopefully all it needs is fluid. Im going to take the cover off and make sure everything is good in there...hope there is no damage. Thanks for your help.
2003 gt
5.4 32v on the way
Haha you are in bellevue? Neat. I had the cover off to mine not too long ago, its all pretty easy to get to and look at on the inside, but I found putting oil back in to be a trick.get a funnel and a decent length of hose if you don't have it.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
13.00 @ 105
![]() iTrader: 1 reviews
sounds like the clutches are shot or maybe the spider gears are worn out
!FACEPLATED!
dont forget the limited slip additive when you put it back together
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
Threads Similar to: Possible rear end problems
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 22 | April 25th, 2011 03:59 PM |
| rear disk brakes and rear end | extropy | Classic Mustangs | 3 | August 11th, 2008 06:41 PM |
| Front End Problems! | 1fast5.0 | 94-95 | 3 | April 9th, 2008 08:32 PM |
| 05 GT installing BMR rear end poly bushing, having problems | miloman | 2005 - 2010 | 4 | March 9th, 2008 03:00 AM |
| Rear End Problems | 01dutchGT | 99-04 | 17 | November 12th, 2007 09:59 AM |
