November 08 ROTM
Help with exhaust clearance with 315/35/17 on 10.5'' wheel. *PICS*
i recently bought a used set of 03/04 cobras, and the rears are 10.5'' out back. currently then have 285/45/17's BFG's on them and they are on their last leg. ive been looking under the car and it looks like 315's will be a tight fit. i have aftermarket 2.5'' tailpipes from the mufflers back. judging from the pics i only have about 1 1/2-2'' of clearance tops.
my question is, going up 30mm in width, will i have any rubbing issues? does anyone have little clearance between their exhaust and 315's? ive done some quick calculations and it looks like the 285's are 11.22'' wide and the 315's are 12.40'' wide. given with tread depth and whatnot, it might be a little off. so there is a difference of 1.18'', and if im right thats only adding .59'' to each side of the tire. just took these a few mins ago. currently has 285's on it. ![]() ![]() thanks for any help guys
![]() ~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~ |
I have 315's and they are almost rubbing against the tailpipes. But havn't caused any problems.
Check my garage for pics and mods! ![]() Originally Posted by svtkidd23 if my gears were a vagina.. id beat it up! |
November 08 ROTM
so with the flowmaster cat back that you have, how big are the tailpipes and how close is it from rubbing? less than 1/2'' or so? thats what im thinking ill have.
2007 Mustang GT
14.70@97.24
Won't the heat of the exhaust do something to the rubber?
2001 mustang bullitt
i am going to go with a 315 soon and i have an slp lm2 cat back would that be any different than ur setup?
November 08 ROTM
i wouldnt think so. tires get warm as you drive more. plus my tailpipes dont get very hot. i can pretty much wrap my hand around them right after driving it.
im not sure. my tailpipes are made for 99-04 mustangs and are 2.5''. ill be pretty upset if i have to adjust the exhaust to fit 315's
Yep Flows 2.5's and there is about 1/2 inch between tire and tailpipe. I check for damage every so often and so far nothing bad has happened.(Looks up says prayer)
November 08 ROTM
that makes me feel better about ordering them next week. but then again, it really depends on who installed them and the placement of the mufflers/tailpipes.
Right on man. Just depends on how your exhaust is set up i guess. Good luck. Your stang looks killer btw!
#10 | |
November 08 ROTM
. i really wanted the stainless bumper inserts but your car looks so good with the black
13.58 @ 102.31
![]() ![]() iTrader: 5 reviews
run dumps lol
November 08 ROTM
lol but that defeats the purpose of me spending $500 on the GT rear bumper and SLP tips. io had them before and caught too much attention for it. it sounded like a dump truck with the old mufflers too haha.
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
ahhaha/\..
i just got my 10.5 with 315's.. no rubbing.. with flows |
November 08 ROTM
i wish i had an exhaust clip. the mufflers were 40 flow's and were at least 4 years old so they were probably blown out and had no function. plus LT's and an O/R H-pipe, it sounded terrible with dumps.
im glad no one is having issues so far, i just wanted to make sure before spending the money. thanks
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 11 reviews
Itll be close but i think youll be fine Kyle. You could always get some 1/8 or 1/4 inch spacer if you HAVE to
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
3rd Place '11 ROTY
'02 GR-40/SLA Saleen
19.34@42.259
I have some rubbing on that section of tailpipe and running 315's on 11"s. I also have no rubber left on the "E" brake cable on the opposite side of wheel. The rubbing would only occur during pretty severe articulation of rear axle. I also have much more articulation than the stock suspension, so fuggetaboutit
![]() Jazzer
#17 | |
![]() iTrader: 1 reviews
you must have a leak..lol i touch mine after running and it burns my hand
#18 | |
I have 315's and I had tons of room but I do have deep dish rims. But now my exhaust is dumped so there no issue.
2000 GT 665/540rwhp/rwtq Best 1/4: AT 431HP 12.29 @ 124 AT 515HP 11.24 @ 129 AT 638HP 11.01 @ 135 AT 665HP ??.?? @ ??? 80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S Trap speed = true measurement of HP.
MM.s Used Car Whore
14.89
yeah nothin the ol sludge hammer cant fix
Threads Similar to: Help with exhaust clearance with 315/35/17 on 10.5'' wheel. *PICS*
| 1'' or 1.25'' wheel spacers? *pics* | buddyantunez1 | 99-04 | 16 | October 7th, 2008 09:16 AM |
| Pic of Wheel clearance | 90Stang | 2005 - 2010 | 1 | August 14th, 2008 12:30 AM |
| Pics with wheel spacers | stanglifemike | 96-98 | 16 | July 24th, 2008 11:58 AM |
| 315/30/18 on a 10 inch wheel?? | lilmarc1988 | 99-04 | 11 | May 4th, 2008 12:17 AM |
| Mac Exhaust Tail pipe clearance to upper control arm problem | 83 5.0 | 5.0 Mustangs | 8 | November 17th, 2006 09:09 AM |
