13.1@105
![]() ![]() iTrader: 6 reviews
SVO 2V Heads
I can get a good deal on a pair of SVO 2V heads. I know it requires either the SVO intake or the NPI one. Now my question is, what are the gains of these heads over stock with a NPI intake? Is there any specs on them?
13.1@105
no one?
1996 Mustang GT coupe
11.99@113.93mph
how much are they asking? HP gains wth a stock intake won't be much and imho, a waste of time, effort and $$$$..... it would be better toget an aftermarket intake, even any of the PI intakes can be port-matched to the SVO heads....
I have some specs on them, do you have access to a fax?
Thumbdinger.com Fish With Protection
is it the ones on corral that i just saw?
if so, it is a great deal and you can use it with bullitt intake and put it on the same way you would as putting a pi intake on npi heads. GREAT gains. and throw some cams in them as welll. |
#5 | |
13.1@105
500 w/ some work that needs to be done. If they're not worth the effort no need to fax the specs. I was under the impression that they outflowed them by quite a bit. |
11.99@113.93mph
ok, well the SVO D-46's will outflow anything out on the market att, $500.00 for the pair? not a bad deal, as they go for @$850.00 each, bare
13.1@105
Yeah, 500 for the pair complete with cams. I'm probably going to have to let it pass due to not wanting to spend the cash right now lol.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the svo heads flow great, i would invest into it if i were to be looking into one. either do a pi intake swap or the svo intake as well. the cumbustion chamber size is larger and will lower compression, the flow is very good, there is room for porting, etc.
i thought they were 500 a peice. which still isnt a bad deal at all
http://www.cardomain.com/ride/3112249 |
hell no thats not bad. they are like 1500 brand new EACH...
get the bullitt intake with it! |
the new trick flow or hardballr intake wont work with svo heads?
mm's nitrous mod
2000 mustang gt
the svo heads were originally made when the npi motors were out. you would have to do a pi adater set up like if you were bolting intake to a npi motor.
Threads Similar to: SVO 2V Heads
| New SVO? | ReverendDexter | The Clubhouse | 12 | July 6th, 2008 10:46 PM |
| svo heads | oompa | 5.0 Mustangs | 16 | January 1st, 2008 03:10 PM |
| SVO Heads vs. PI | RandoGT | 96-98 | 49 | December 19th, 2007 05:56 PM |
| SVO heads.... | Casper98GT | Modular Mustangs | 1 | March 21st, 2007 07:22 PM |
| 96-98 svo heads? | acg | 96-98 | 21 | March 17th, 2007 05:13 PM |
