re-using intake manifold gaskets
has anyone done this or know anyone that has... would it cause problems?
2000 GT
I would play it safe. Coolant in the intake is never a good thing... thats what blew my motor.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
anyone else?
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
they can be reused as long as there are no tears in the gasket rings. i have had my intake off several times without any issues at all.
awesome hope it works for me
mm's nitrous mod
2000 mustang gt
just check the rubber sealing rings around the port opening. if they are good, then you will be just fine. i think i have had my intake on and off about 5 times without any issues at all on my gt. the gaskets had to be replaced the first time we pulled the intake off the mach.
ill look at the silicone seals on the gasket... thats what you are refering to correct
1996 Mustang GT coupe
11.99@113.93mph
more of my $.02 worth:
if were talking about a Ford intake wth the gaskets, yes they can be reused over and over as long as the sealing surface is undamaged...but for @$24.00 for a set of oem intake gaskets, I wouldn't reuse them more than once, but thats me ![]() now, some of the aftermarket intake: ie dorman; use O-Rings that are incorperated in the lower part of the intanke mainfold that may Not be serviceable if damaged and if thats the case, then your screwed, thats why I'll always insist on buying oem
Thumbdinger.com Fish With Protection
thanks randy
Threads Similar to: re-using intake manifold gaskets
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 21st, 2010 12:20 AM |
| Replacing intake manifold gaskets... | SteviGX | 96-98 | 4 | May 28th, 2008 09:34 PM |
| Intake Manifold | ModMustang97GT | Modular Mustangs | 22 | December 31st, 2007 03:12 PM |
